STM32F3 ports
mapy
Re: STM32F3 ports
Post by mapy » Thu Jan 31, 2019 8:06 am
Hello Romeo, once you finish it I will be pleased yo help you testing it.
Enviado desde mi WIM mediante Tapatalk
romeo
Re: STM32F3 ports
Post by romeo » Tue Feb 05, 2019 4:54 am
I have finished the draft for the af table. But I'm wondering if STM32F091 doesn't fit better as header! On the second line, in the STM32F3 there is no additional description (starting from page 45 in the datasheet) https://www.st.com/resource/en/datashee ... f303vc.pdf
Any suggestion?
Thank you,
Romeo
romeo
Re: STM32F3 ports
Post by romeo » Tue Feb 05, 2019 6:01 pm
Ok. Thank you! I will post once it is finished. Now I'm comparing with STM32F091. It seems to be much similar!
romeo
Re: STM32F3 ports
Post by romeo » Wed Feb 06, 2019 4:27 pm
Hello!
@mapy I just finished the csv file for stm32f303.
Are there any other modifications to do?
Thank you,
Romeo
romeo
Re: STM32F3 ports
Post by romeo » Thu Feb 07, 2019 6:32 pm
Hi all,
I got stuck here:
Reading makefiles...
Updating goal targets....
 File 'all' does not exist.
   File 'build-STM32F3DISC/firmware.dfu' does not exist.
     File 'build-STM32F3DISC/firmware.elf' does not exist.
       File 'build-STM32F3DISC/py/mpstate.o' does not exist.
         File 'build-STM32F3DISC/genhdr/qstrdefs.generated.h' does not exist.
           File 'build-STM32F3DISC/modstm_qstr.h' does not exist.
          Must remake target 'build-STM32F3DISC/modstm_qstr.h'.
mapy
Re: STM32F3 ports
Post by mapy » Thu Feb 07, 2019 7:07 pm
Hello Romeo, I am relatively new in micropython so I have not the required knowledges yo help you on creating the port, I am really sorry about that. Once finished I could test It in the many different boards we have in my company with STM32F3. Thank you very much.
Re: STM32F3 ports
Post by dhylands » Thu Feb 07, 2019 8:37 pm
Romeo - can you give me a pointer to your micropython repository and stm32lib repository? And the name of the board you were trying to build?
romeo
Re: STM32F3 ports
Post by romeo » Fri Feb 08, 2019 5:20 pm
dhylands wrote:Romeo - can you give me a pointer to your micropython repository and stm32lib repository? And the name of the board you were trying to build?
Hello!
The board I have is STM32F3 DISCOVERY.
The github repository is https://github.com/sfynxu/stm32f3discovery_upy
Thanks,
Romeo
Re: STM32F3 ports
Post by dhylands » Fri Feb 08, 2019 7:05 pm
It looks like the first problem is that the CMSIS_MCU in your mpconfigboard.mk file has a typo. It shows:
CMSIS_MCU = STM32F303xx
I think that this is supposed to be:
CMSIS_MCU = STM32F303xC
The Makefile looks for this file ../../lib/stm32lib/CMSIS/STM32F3xx/Include/$(CMSIS_MCU - in lower case).h which doesn't exist.
That gets past the modstm problem, and now it runs into an issue in pllvalues.py
Re: STM32F3 ports
Post by dhylands » Fri Feb 08, 2019 7:09 pm
I got around the pll problem by changing the definition of HSE_VALUE in boards/STM32F3DISC/stm32f3xx_hal_conf.h from:
  #define HSE_VALUE    (8000000U) /*!< Value of the External oscillator in Hz */^M
to be
  #define HSE_VALUE    ((uint32_t)8000000) /*!< Value of the External oscillator in Hz */
