micropython variable argument macro define compilation errors with keilv5.18
Posted: Wed Jun 21, 2017 5:05 am
I was using micropython library for my project with CoIDE with gcc tool chain.
There is no problem of compilation.
Later i shifted to Keil IDE with armcc tool chain.
But i have compilation errors in variable argument macro defines code.
In micropython/py/grammar.h file the following macro defines are present
Only 2 defines are given. There are lot more in the header file
DEF_RULE(single_input, nc, or(3), tok(NEWLINE), rule(simple_stmt), rule(compound_stmt))
DEF_RULE(file_input, c(generic_all_nodes), and_ident(1), opt_rule(file_input_2))
In micropython/py/parse.c file the following is the definition
STATIC const rule_t *const rules[] = {
#define DEF_RULE(rule, comp, kind, ...) &rule_##rule,
#include "py/grammar.h"
#undef DEF_RULE
In micropython/py/comple.c file the following is the definition
typedef enum {
#define DEF_RULE(rule, comp, kind, ...) PN_##rule,
#undef DEF_RULE
PN_maximum_number_of,
PN_string, // special node for non-interned string
PN_bytes, // special node for non-interned bytes
PN_const_object, // special node for a constant, generic Python object
} pn_kind_t;
Keil throws the following type of errors
..\..\..\Micropython\py\grammar.h(81): error: #1077: an initializer cannot be specified for a flexible array member
EF_RULE(single_input, nc, or(3), tok(NEWLINE), rule(simple_stmt), rule(compound_stmt)) //6 arguments
..\..\..\Micropython\py\grammar.h(82): error: #1077: an initializer cannot be specified for a flexible array member
EF_RULE(file_input, c(generic_all_nodes), and_ident(1), opt_rule(file_input_2)) //4 arguments
..\..\..\Micropython\py\grammar.h(83): error: #1077: an initializer cannot be specified for a flexible array member
Pl help me to fix these type of errors.
#undef DEF_RULE
typedef enum {
#undef DEF_RULE
} pn_kind_t;
