RAM in stm32l476
ajie_dirgantara
RAM in stm32l476
Post by ajie_dirgantara » Thu Aug 03, 2017 9:23 am
    GNU linker script for STM32L476XG
/* Specify the memory areas */
MEMORY
    FLASH (rx)      : ORIGIN = 0x08000000, LENGTH = 1024K
    FLASH_ISR (rx)  : ORIGIN = 0x08000000, LENGTH = 0x0004000 /* sectors 0-7, 16 KiB */
    FLASH_TEXT (rx) : ORIGIN = 0x08004000, LENGTH = 0x007C000 /* sectors 8-255, 496 KiB */
    FLASH_FS (r)    : ORIGIN = 0x08080000, LENGTH = 0x0080000 /* sectors 256-511 512 KiB */
    RAM (xrw)       : ORIGIN = 0x20000000, LENGTH = 96K
    SRAM2 (xrw)     : ORIGIN = 0x10000000, LENGTH = 32K
ENTRY(Reset_Handler)
/* produce a link error if there is not this amount of RAM for these sections */
_minimum_stack_size = 2K;
_minimum_heap_size = 16K;
/* Define the top end of the stack.  The stack is full descending so begins just
   above last byte of RAM.  Note that EABI requires the stack to be 8-byte
   aligned for a call. */
_estack = ORIGIN(RAM) + LENGTH(RAM);
/* define common sections and symbols */
INCLUDE common.ld
/* RAM extents for the garbage collector */
_ram_start = ORIGIN(RAM);
_ram_end = ORIGIN(RAM) + LENGTH(RAM);
_heap_start = _ebss; /* heap starts just after statically allocated memory */
_heap_end = 0x20014000;
_flash_fs_start = ORIGIN(FLASH_FS);
_flash_fs_end   = ORIGIN(FLASH_FS) + LENGTH(FLASH_FS);
From the linker script above, I don't think it make use of the SRAM2. Can this be enabled so we can get more RAM from SRAM2?
chrismas9
Re: RAM in stm32l476
Post by chrismas9 » Sat Aug 05, 2017 5:35 pm
Unlike some STM32's SRAM2 is not contiguous with SRAM1 in the L476. Currently SRAM2 is used as cache for the Flash FS when internal Flash is used. Since the L476 has 2K page size 30K of SRAM2 is wasted.
By reducing the FS cache to 2K and moving the stack into the remaining 30K of SRAM2 I have been able to increase the heap by 16K and the stack by 14K. There is an experimental version here:
https://github.com/chrismas9/micropytho ... ganisation
It only builds for L476. The linker scripts need to be modified for all the other STM32 MCU's. I plan to submit a PR covering all STM32's after more testing and feedback.
The changes to the linker script also allow you to increase the cache size on MCU's with large sectors and enough ram. With 128k cache you can get between 512K and 1.5M of internal Flash FS.
