Sometimes after reset my files main.py and boot.py are corrupted and are made of dots only (....).
My board flashes then two LEDs for a while and does not run my files.
I cannot find why and when is it happening. Any ideas?
Thanks in advance
[stm32f4-disco] Problem after reset
Re: [stm32f4-disco] Problem after reset
It turned out that the whole difference is in unmounting the device from my PC with windows7.
After every change in python files, I have to do remove safely.
That way the files will not be corrupted.
The sure way to avoid file corruption with all MicroPython targets is to disable MSC (USB mass storage) mode in boot.py and manage the filesystem using a tool like rshell https://github.com/dhylands/rshell. There is a fundamental problem in that USB mass storage is a single master design that assumes that the USB subsystem is a dumb disk drive which cannot modify the files. Obviously a MicroPython device can. Sooner or later that will jump up and bite you
In my view the official docs should suggest this way of working but I guess MSC mode is simple and intuitive for beginners.
