bare metal Raspberry Pi Zero port
boochow
Re: bare metal Raspberry Pi Zero port
Post by boochow » Sat Dec 07, 2019 11:31 pm
Since I have been adding no code to my repo this year, the code you see on the github is the latest one.
Trekintosh
Post by Trekintosh » Sat Dec 14, 2019 7:50 pm
How difficult would it be to bring the code up to the current version of MicroPython?
boochow
Post by boochow » Sun Dec 15, 2019 4:11 am
No difficulties.
I just have updated the repository and now it can be built with MicroPython v1.11.
ZuluSpl0it
Post by ZuluSpl0it » Mon May 04, 2020 5:11 pm
I've updated to MicroPython 1.12 on my fork:
https://github.com/ZuluSpl0it/micropython-raspberrypi
and I've put in a pull request to get it on the parent repo.
I was trying to enable the Native emitter by changing the options in mpconfigport.h. I've tried
#define MICROPY_EMIT_THUMB (1)
and
#define MICROPY_EMIT_ARM (1)
the @micropython.native decorator is now recognized, but the raspi Zero W hangs.
While running a performance test (just incrementing a variable in a loop for 1 second and then reporting the total):
On a ESP8266 I get:
No Optimization Count: 30278
Just preloading class Count: 45119
Native emitter only Count: 45440
Preload class plus Native emitter Count: 81750
On the raspi Zero W I get:
No Optimization Count: 43886
Just preloading class Count: 71338
then it just hangs for the function with the @micropython.native decorator
Any ideas on what I can try? Or am I enabling the wrong options?
PH1LJ
Post by PH1LJ » Thu May 07, 2020 4:44 pm
can you please help
I'm trying to create a bare-metal usd card for my Pi zero, I'm pretty sure I created the usd card as per the detail
but all I see is the rainbow screen on the pi.
Just to confirm - all I have on the USD is shown below :-
build folder with firmware.img
bootcode.bin
config.txt
start.elf
Any ideas
ZuluSpl0it
Post by ZuluSpl0it » Fri May 08, 2020 1:08 pm
Are you able to connect via the REPL? Did you use the main repo or a fork to build?
