Page 1 of 2
nRF52840 - HolyIot Board Definition
Posted: Fri Oct 26, 2018 1:17 pm
by devnull
I am trying to create a board definition for the HolyIot board (Holyiot_18010), but are unsure what the following is for:
Does anybody know ?
Re: nRF52840 - HolyIot Board Definition
Posted: Fri Oct 26, 2018 1:20 pm
by devnull
Also, if I comment out flow control, will that disable flow control ??
// #define MICROPY_HW_UART1_CTS (7)
// #define MICROPY_HW_UART1_RTS (5)
Posted: Fri Oct 26, 2018 1:24 pm
by devnull
OK, I am guessing that MICROPY_HW_UART1_HWFC is Hardware Flow Control, and that setting it to 0 will disable flow control ?!
Posted: Fri Oct 26, 2018 1:38 pm
by WhiteHare
Good question. I'm guessing the answer is yes, because the default for the hardware is no flow control (see 6.33.10.13 CONFIG in the Nordic nRF52840 datasheet). So, if you defeat whatever micropython code enables it, it should default to no flow control on the uart.
Posted: Fri Oct 26, 2018 1:48 pm
by devnull
Well this is the definition I have created, but not yet tested.
I am assuming the port numbers are contiguous starting with Port 0 (32 bits) followed by Port 1 (16 bits).
It uses the outer top 3/4 pins on the left and right hand side for SPIO and UART1, no Flow Control and no LEDs.
@@ PORT 0 @@
0 = P0.0
09 = P0.09 << RX
10 = P0.10 << TX
31 = P0.31
@@ PORT 1 @@
32 = P1.00
33 = P1.01
34 = P1.02
42 = P1.10 << SCLK
43 = P1.11 << MOSI
44 = P1.12
45 = P1.13 << MISO
46 = P1.14
47 = P1.15
#define MICROPY_HW_BOARD_NAME "holyiot_18010"
#define MICROPY_HW_MCU_NAME "NRF52840"
#define MICROPY_PY_SYS_PLATFORM "nrf52840-PDK"
#define MICROPY_PY_MACHINE_UART (1)
#define MICROPY_PY_MACHINE_HW_PWM (1)
#define MICROPY_PY_MACHINE_HW_SPI (1)
#define MICROPY_PY_MACHINE_TIMER (1)
#define MICROPY_PY_MACHINE_RTCOUNTER (1)
#define MICROPY_PY_MACHINE_I2C (1)
#define MICROPY_PY_MACHINE_ADC (1)
#define MICROPY_PY_MACHINE_TEMP (1)
#define MICROPY_PY_RANDOM_HW_RNG (1)
// LEDS - NOT USED
#define MICROPY_HW_HAS_LED (0)
#define MICROPY_HW_LED_COUNT (0)
#define MICROPY_HW_LED_PULLUP (0)
// #define MICROPY_HW_LED1 (13) // LED1
// #define MICROPY_HW_LED2 (14) // LED2
// #define MICROPY_HW_LED3 (15) // LED3
// #define MICROPY_HW_LED4 (16) // LED4
// UART config
#define MICROPY_HW_UART1_RX (9) // P0.09
#define MICROPY_HW_UART1_TX (10) // P0.10
// UART FLOW CONTROL
#define MICROPY_HW_UART1_HWFC (0) // Hardware Flow Control
// SPI0 config
#define MICROPY_HW_SPI0_NAME "SPI0"
#define MICROPY_HW_SPI0_SCK (42) // P1.10
#define MICROPY_HW_SPI0_MOSI (43) // P1.11
#define MICROPY_HW_SPI0_MISO (45) // P1.13
#define MICROPY_HW_PWM0_NAME "PWM0"
#define MICROPY_HW_PWM1_NAME "PWM1"
#define MICROPY_HW_PWM2_NAME "PWM2"
#if 0
#define MICROPY_HW_PWM3_NAME "PWM3"
#endif
//#define HELP_TEXT_BOARD_LED "1,2,3,4"
Posted: Fri Oct 26, 2018 2:04 pm
by WhiteHare
I haven't looked into what micropython's pin naming convention is, so I'm curious what you find out. I can say for sure though that it can vary from one platform to another (e.g. mbed's pin naming convention is different than what the Segger Embedded IDE does).
Posted: Sat Oct 27, 2018 6:13 am
by devnull
Setting:
Does disable Flow Control.
But simply changing from :
TX: 6 > 10
RX: 8 > 9
Does not work, it appears that 9 & 10 are used for the NFC antannae, switching to 22(0.22) and 32(1.0) works.
Also, 18 is assigned to /reset.
Posted: Sat Oct 27, 2018 12:54 pm
by WhiteHare
Nice work.
Yeah, 9 and 10 can be made to work by disabling NFC on them, but they are slightly crippled (relative to other pins) even if you do, so I think you're right: it's best to avoid them if you can.
Posted: Sat Oct 27, 2018 1:13 pm
by WhiteHare
BTW, if you haven't already, you may want to look into Nordic's nRF52840-DONGLE. At $10, it's only slightly more than your HolyIOT. Also, it passed FCC (which I don't know if that matters, since you are in Singapore). On the other hand, the HolyIOT has more pins exposed, so there is that in its favor.
Posted: Sat Oct 27, 2018 2:14 pm
by devnull
Funny you should mention that, last Friday I ordered 2 of them from Farnell, that was before I made progress with the holyiot
