Page 3 of 4
Re: [nRF52] How to get rshell to work with an nRF52?
Posted: Mon Oct 29, 2018 7:12 pm
by dhylands
Hmm.
If you connect via the regular REPL, what does the output of:
>>> import sys
>>> sys.stdin.buffer
show?
Posted: Mon Oct 29, 2018 7:54 pm
by WhiteHare
dhylands wrote: ↑Mon Oct 29, 2018 7:12 pm
Hmm.
>>> import sys
>>> sys.stdin.buffer
show?
MicroPython v1.9.4-651-g0f6f86ca4-dirty on 2018-10-27; PCA10056 with NRF52840
>>> import sys
>>> sys.stdin.buffer
File "<stdin>", in <module>
AttributeError: 'module' object has no attribute 'stdin'
Posted: Mon Oct 29, 2018 9:12 pm
by dhylands
Yeah - rshell needs sys.stdin and sys.stdout to work properly.
I have an NRF52840 dongle (
https://www.nordicsemi.com/eng/Products/nRF52840-Dongle) that I'll see about creating a board definition for and see what I can get running on that.
Posted: Wed Nov 28, 2018 4:21 am
by rdagger
I noticed Mouser now has the
nRF52840-Dongle in stock for $10. I've been waiting for a supported BLE MicroPython chip.
Is rshell compatible?
Are prebuilt binaries available?
How does the MicroPython port compare to the CircuitPython port?
Posted: Mon Dec 03, 2018 7:30 pm
by WhiteHare
rdagger wrote: ↑Wed Nov 28, 2018 4:21 am
AFAIK, there still is no micropython release for the dongle. You can run the bbc:microbit firmware on it, but the filesystem is minuscule and doesn't tap the potential of the much larger flash size of the nRF52840. I had to switch to a different language because of this.
Posted: Mon Dec 03, 2018 7:44 pm
by rdagger
WhiteHare wrote: ↑Mon Dec 03, 2018 7:30 pm
Thanks for the info. It looks like
Circuit Python v.4 Alpha 3 supports the dongle. I'm not sure if a J-link is required. The site mentions that the dongle can be programmed by DFU but it is vague on the details.
Posted: Tue Dec 04, 2018 12:59 am
by tannewt
(CircuitPython dev here.)
At this point its pretty different, we started with glennrub and tralamazzas nrf5 PR (
https://github.com/micropython/micropython/pull/3137) into MicroPython and a bunch of work has been done on it since then including non-vendor support for USB (available outside of CircuitPython here:
https://github.com/hathach/tinyusb/tree/develop/)
I'm happy to answer any further questions about it.
Posted: Tue Dec 04, 2018 2:44 am
by rdagger
I've pieced together install instructions from different sites. Assuming I don't have a J-link and I want to load CircuitPython on an nRF52840-dongle (PCA10059) will the following work?:
1. Download the pre-compiled bin file
here for the PCA10059.
2. Run the script
download_ble_stack.sh from the CP repo
ports/nrf/bluetooth folder to download the soft device files.
3. Plug the PCA10059 into a computer's USB port and press the reset button.
4. Use Nordic's
nRF Connect Desktop to load the bin file and SD file.
Thanks.
Posted: Wed Dec 05, 2018 7:17 am
by tannewt
That sounds like it will work but I haven't done it that way myself. I've only done it with a JLink at this point.
One other option would be to install the nRF UF2 bootloader first and then use the CircuitPython UF2 to install it. The bootloader's repo is here:
https://github.com/adafruit/Adafruit_nRF52_Bootloader I believe the instructions in the README are up-to-date (though I've only used a JLink).
Posted: Fri Sep 13, 2019 12:04 pm
by sebi
dhylands wrote: ↑Mon Oct 29, 2018 9:12 pm
I have an NRF52840 dongle ... that I'll see about creating a board definition for and see what I can get running on that.
Did you advance on that topic? I have a similar issue using rshell with an nRF52832 MCU.
I have registered the errors encountered in this post
viewtopic.php?f=12&t=6961#p39621.
Maybe MICROPY_PY_SYS_STDFILES and MICROPY_PY_SYS_STDIO_BUFFER need to be enabled in mpconfigport.h to get the buffered stdio activated. (But `make` fails with those features on.)
