SAMD21 board..slow SPI?
winneymj13
Post by winneymj13 » Sat Nov 10, 2018 2:44 am
I have been writing a driver for the SH1106 Driver based OLED display and it is running extremely slow (about 2 frames per second). The SH1106 display uses paging which means I cannot write all the bytes via SPI in a single byte stream. I have set up the SPI seen below.
Although it could be my code above being slow, I have seen examples of code using machine.SPI to use the hardware SPI. I tried to import machine, but it does not appear to exist, and I see in the circuitpython documentation "No machine API on Atmel SAMD21 port."
Does this mean there is no Hardware SPI implemented?
[code]
# Create the SPI interface.
spi_bus = busio.SPI(board.SCK, board.MOSI)
spi_bus.try_lock()
spi_bus.configure(baudrate=24000000, polarity=0, phase=0)
spi_bus.unlock()
[/code]
Code to write the frame buffer in the driver is below:
def write_framebuf(self):
"""write to the frame buffer via SPI"""
for page in range(0, 7): # Pages
page_mult = (page << 7)
self.write_cmd(0xB0 + page) # set page address
self.write_cmd(0x02) # set lower column address
self.write_cmd(0x10) # set higher column address
self.dc_pin.value = 1
with self.spi_device as spi:
spi_write = spi.write
for pixel in range (0, self.width):
spi_write(bytearray([self.buffer[page_mult + pixel]]), end=1)
Any suggestions on how to speed up the method above is greatly appreciated.
Mark
tannewt
Re: SAMD21 board..slow SPI?
Post by tannewt » Mon Nov 12, 2018 9:28 pm
Hi Mark,
Please post on the Adafruit CircuitPython forum here: https://forums.adafruit.com/viewforum.php?f=60
That's where we support CircuitPython.
Thanks!
~Scott
