[Tiva TM4C123] [solved] I'm getting a hard fault when initializing a Pin
ExXec
Post by ExXec » Sat Dec 15, 2018 8:17 pm
Hey everybody,
I'm currently in the process of porting uPy to the Tiva Launch Pad.
I'm having problems calling
>>> p = Pin('PF2', Pin.OUT)
because the controller goes into the FaultISR(). (Handler for hard faults)
I suspect a nullpointer dereference, but not in my own code, so I have no idea why.
'PF2' is a valid pin name.
The callstack looks like this:
Callstack
And in this line the fault happens:
Line of fault
I cannot step into it.
Here are the values of the local variables right before the call:
Local Variables
Does anybody know why this is happening?
I'm grateful for any ideas!
-ExXec
My fork: https://github.com/ExXeptional/micropyt ... ts/tm4c123
Re: [Tiva TM4C123] I'm getting a hard fault when initializing a Pin
Post by dhylands » Sun Dec 16, 2018 12:18 am
You show that fun_in is 0x00000000 so the address of the routine you're trying to call is the null pointer, which is what's causing the exception and why you can't step into it.
So you need to work backwards and figure out why fun_in is null.
ExXec
Post by ExXec » Sun Dec 16, 2018 1:43 am
Ok, I tracked it down to this expression:
MP_STATE_PORT(pin_class_mapper)
this returns 0x00000000
I copied that part from the stm32 port, so I don't know what this does
Post by dhylands » Sun Dec 16, 2018 6:11 am
The code only calls that function if pin_class_mapper is not equal to mp_const_none. mp_const_none isn't the value 0x00000000
pin_class_mapper is initialized to mp_const_none in the function pin_init0 which should be called from your main.c as it is here:
https://github.com/micropython/micropyt ... ain.c#L587
ExXec
Post by ExXec » Sun Dec 16, 2018 6:15 pm
yeah that was the problem, thanks :D
