[TM4C123] Assertion failed
ExXec
Post by ExXec » Sat Dec 15, 2018 8:31 pm
Hey everybody,
I'm in the process of porting uPy to the Tiva Launchpad.
I recently finished some of the pin control and while testing on the REPL I noticed this assertion error:
	from umachine import Pin
	p = Pin.board.PF2
	p.init(Pin.OUT)
	p.on()
	p.off()
	p.on()
	p.off()
Assertion 'MP_PARSE_NODE_STRUCT_KIND(pns) <= PN_const_object' failed, at file ../../py/compile.c:2746
What is causing this?
I suspect a GC issue, because the board only has 32kB SRAM? But I have no idea really
-ExXec
jickster
Re: [TM4C123] Assertion failed
Post by jickster » Sat Dec 15, 2018 8:46 pm
Let’s eliminate those function calls and see if it still happens.
Try it with simper code like
a = 55
a = a * 55
b = a + 87
etc
Keep typing simple lines and let us know if you see the same issue.
ExXec
Post by ExXec » Sat Dec 15, 2018 9:11 pm
So I did this and I got a different error this time
MicroPython v1.9.4-799-g89944c591-dirty on 2018-12-15; Tiva Launch Pad with TM4C123G6HPM
>>> a = 9
>>> b = 8
>>> c = 7
>>> d = 6
>>> c = 5
>>> b = 4
>>> a = 3
>>> b = 2
>>> c = 1
Assertion 'l < emit->max_num_labels' failed, at file ../../py/emitbc.c:496
jickster
Post by jickster » Sat Dec 15, 2018 9:26 pm
Did you actually create a heap for uPy and pass its pointer to mp_init ?
ExXec
Post by ExXec » Sat Dec 15, 2018 9:48 pm
This is from my main.c:
This is just from the minimal port with slight alterations
The flag MICROPY_ENABLE_GC is set to 1
#if MICROPY_ENABLE_GC
static char heap[2048];
#endif
int main(int argc, char **argv) {
    int stack_dummy;
    stack_top = (char*)&stack_dummy;
    gc_init(heap, heap + sizeof(heap));
    #endif
    mp_init();
    #if MICROPY_ENABLE_COMPILER
    #if MICROPY_REPL_EVENT_DRIVEN
    pyexec_event_repl_init();
    for (;;) {
        int c = mp_hal_stdin_rx_chr();
        if (pyexec_event_repl_process_char(c)) {
            break;
    #else
    pyexec_friendly_repl();
    #endif
    //do_str("print('hello world!', list(x+1 for x in range(10)), end='eol\\n')", MP_PARSE_SINGLE_INPUT);
    //do_str("for i in range(10):\r\n  print(i)", MP_PARSE_FILE_INPUT);
    #else
    pyexec_frozen_module("frozentest.py");
    #endif
    mp_deinit();
    return 0;
jickster
Post by jickster » Sat Dec 15, 2018 10:17 pm
What exact release of uPy are you using?
1.9.3?
1.9.4?
ExXec
Post by ExXec » Sat Dec 15, 2018 11:11 pm
Oh, I didn't use a specific version, I forked it at somepoint and then worked from there.
Latest commit is from 10.Dec this year.
So 1.9.4 I guess?
jickster
Post by jickster » Sat Dec 15, 2018 11:19 pm
ExXec wrote:Oh, I didn't use a specific version, I forked it at somepoint and then worked from there.
So 1.9.4 I guess?
To eliminate that variable, please use a specific version.
Monday I’ll run your exact code and see what happens.
ExXec
Post by ExXec » Sat Dec 15, 2018 11:24 pm
Ok thank you so far!
jickster
Post by jickster » Sat Dec 15, 2018 11:25 pm
ExXec wrote:Ok thank you so far!
Ok. What release version are you using?
