Right now I am using "uPyCraft IDE" for my "STM32-F767ZI NUCLEO" board on my Windows 10 system,
I am also using PUTTy to code small codes in my board and it runs perfectly with putty but when I am trying it with uPyCraft board is not showing any response.
Any one plssss can help me.Provide me any link if some one work on stm32 and micropython and if there any more suitable IDE for stm-32 board then pleasssss tell us.
thank you
Micropython IDE for STM32F767ZI Board (Windows 10)
Re: Micropython for STM32F767ZI Board
You can build for the NUCLEO_F767ZI by going to micropython/ports/stm32 and doing:
make BOARD=NUCLEO_F767Zi
Re: Micropython IDE for STM32F767ZI Board (Windows 10)
Hi, I have the same problem but I have the F401RE Core.The problem where I find the path:
Then I guess he's got to have a compiler.
Thank you
chipxx (richard)
Thank you
chipxx (richard)
The micropython directory will exist wherever you clone the repository to. ports/stm32 will be found inside that micropython directory.
The toolchain needs to be installed someplace on your computer and you need to setup the PATH so that you can run arm-none-eabi-gcc from the command line.
If the toolchain is setup properly you should be able to type: and then get the following error:
arm-none-eabi-gcc
arm-none-eabi-gcc: fatal error: no input files
compilation terminated.
