[nRF52832] REPL UART is not shown up
Posted: Fri Mar 08, 2019 5:36 am
by lnsri22
Hello Everyone!!
After building the firmware successfully for nrf port , I could not see a REPL uart that is thrown by the device.
What could be the possible cause?
FYI
The command I'm issuing to make is
make BOARD=pca10040 SD=s132 flash FROZEN_MPY_DIR=freeze
Re: [nRF52832] REPL UART is not shown up
Posted: Mon Mar 11, 2019 9:25 pm
by c45713
Have you enabled the MICROPY_PY_BLE_NUS (1) in bluetooth_conf.h by mistake?
If so, this will route all UART REPL to BLE UART Service.
Posted: Thu Mar 14, 2019 5:26 am
by lnsri22
Hello c45713,
Thank you so much for the quick reply there!!
I have not enabled it in the config file.
Tried to attach a screenshot. But could not do due to technical problem with uploading attachment
Posted: Fri Mar 15, 2019 9:47 pm
by c45713
Great. Then that is not an issue.
Could you make sure that you are starting fresh on the pca10040 by issuing the following sequence:
nrfjprog --eraseall -f nrf52
make BOARD=pca10040 SD=s132 clean
make BOARD=pca10040 SD=s132 sd
Does this work any better?
Posted: Tue Mar 19, 2019 5:05 am
by lnsri22
Thanks again c45713!!
Let me give it a try and update you!!
Posted: Fri Aug 16, 2019 4:45 pm
by knowic
Hello, sir,
Have you get your issue fixed now? I have the same questions.
thanks .
Jason Hu
