[nRF52840] UART service advertising error.
Sunghwan_Chung
Post by Sunghwan_Chung » Tue Mar 12, 2019 1:26 pm
Hello!
I try to connect through UART(Serial) with nRFConnect App.
Error found at the advertise function.
>>> import spp
>>> sc = spp.SPP()
SoftDevice enabled
1. setName(name), default is nrf52_SPP .
2. start() : start service and advertise
>>> sc.start()
File "<stdin>", in <module>
File "spp.py", in start
OSError: Can not apply advertisment data. status: 0x09
When use advertise() without params. It return no error and get any error during connect with iPhone App.
But, disconnected and connect continuously and unable transfer data. Code is below.
from board import LED
from ubluepy import Service, Characteristic, UUID, Peripheral, constants
import ble
class SPP:
deviceName = "nrf52_SPP"
conFlag = False
# start off with LED(1) off
led = LED(1)
# the Nordic UART Service.
uuid_spp_vender_specific = UUID("6E400001-B5A3-F393-E0A9-E50E24DCCA9E")
uuid_spp_rx_characteristic = UUID("6E400002-B5A3-F393-E0A9-E50E24DCCA9E")
uuid_spp_tx_characteristic = UUID("6E400003-B5A3-F393-E0A9-E50E24DCCA9E")
periph = Peripheral()
service_SPP = Service(uuid_spp_vender_specific)
SPP_rx_pros = Characteristic.PROP_WRITE
SPP_rx_attrs = Characteristic.ATTR_CCCD
SPP_rx_characteristic = Characteristic(uuid_spp_rx_characteristic, props = SPP_rx_pros, attrs = SPP_rx_attrs)
service_SPP.addCharacteristic(SPP_rx_characteristic)
SPP_tx_pros = Characteristic.PROP_NOTIFY
SPP_tx_attrs = Characteristic.ATTR_CCCD
SPP_tx_characteristic = Characteristic(uuid_spp_tx_characteristic, props = SPP_tx_pros, attrs = SPP_tx_attrs)
service_SPP.addCharacteristic(SPP_tx_characteristic)
receiveddata = None
def __init__(self):
ble.enable()
self.led.off()
self.conFlag = False
print('1. setName(name), default is ', self.deviceName, '.')
print('2. start() : start service and advertise')
return
def close(self):
pass
def start(self):
self.periph.addService(self.service_SPP)
self.periph.setConnectionHandler(self.event_handler)
self.periph.advertise(device_name=self.deviceName, services=[self.service_SPP])
return
def setName(self, data):
if len(data) > 0:
self.deviceName = data
return
def sendStr(self,strdata):
self.SPP_rx_characteristic.write(strdata.encode('utf-8'))
return
def getData(self):
if self.receiveddata != None:
strReceived = self.receiveddata.decode('utf-8')
print('Rcv:', strReceived)
return strReceived
return None
def event_handler(self, id, handle, data):
if id == constants.EVT_GAP_CONNECTED:
# indicated 'connected'
print('\nEVT_GAP_CONNECTED')
self.conFlag = True
self.led.on()
self.sendStr('hello.')
elif id == constants.EVT_GAP_DISCONNECTED:
# indicate 'disconnected'
print('\nEVT_GAP_DISCONNECTED')
self.led.off()
# restart advertisment automatically
elif id == constants.EVT_GATTS_WRITE:
# write to this Characteristic is to CCCD
print('\nEVT_GATTS_WRITE:', data.decode('utf-8'))
self.receiveddata.append(data)
elif id == constants.EVT_GATTS_READ:
print('\nEVT_GATTS_READ:', data.decode('utf-8'))
print('\nNot defined id :', id, '\ndata:', data)
