[Tiva TM4C123] UART write succeeds but throws OSError 116
ExXec
Post by ExXec » Mon Apr 15, 2019 2:20 pm
Hey,
can someone tell me, where the errno 116 can be issued in the call stack for UART?
I can't find the line.
I didn't find this error code in the errno table, but I read in another post, that this is a timeout error.
I'm having trouble getting it to work, it successfully sends the data but shows
>>> uart.write('hallo')
  File "<stdin>", in <module>
OSError: 116
This only happens with free running code, if I step manually from stream.c:233 it works just fine.
Thanks,
-ExXec
Re: [Tiva TM4C123] UART write succeeds but throws OSError 116
Post by dhylands » Mon Apr 15, 2019 2:49 pm
OSError 116 is ETIMEDOUT.
For the pyboard, there are 2 places:
https://github.com/micropython/micropyt ... art.c#L676
https://github.com/micropython/micropyt ... art.c#L696
Both in the uart_tx_data function. This could be flow control related, or the timeout specified when the UART was opened is too small for the baud rate?
It could also happen if HAL_GetTick isn't accurate since that's how the UART determines if the timeout has expired or not.
ExXec
Post by ExXec » Mon Apr 15, 2019 3:00 pm
Ah, I see.
This is really strange, because my IDE says MP_ETIMEDOUT is defined as 110.
So I got confused where 116 is coming from.
Thank you!
Post by dhylands » Mon Apr 15, 2019 3:24 pm
mperrno.h has 2 sets of error codes depending on how MICROPY_USE_INTERNAL_ERRNO is set i your mpconfigport.h
The pyboard has MICROPY_USE_INTERNAL_ERRNO set to 1 which would make MP_ETIMEDOUT be 110. But if it's not defined or set to zero, the MP_ETIMEDOUT will be set to ETIMEDOUT which comes from toolchain errno.h. For ARM, ETIMEDOUT is 116.
