Hello, I have another newbie answer. I have written a very simple program which only sends some messages via UART. The code is:
from pyb import UART
import utime
uart = UART(4, 9600)
counter = 0
for counter in range(10):
uart.write(str(counter))
utime.sleep_ms(100)
But after uploading and resetting I will get the message:
File "main.py", line 4, in <module>
ValueError: UART(4) doesn't exist
MicroPython v1.10-381-g4f4477872 on 2019-05-23; NUCLEO-L476RG with STM32L476RG
I will get this message also using an other index for UART. Could you please help me?
Thanks in advanve!
UART(4) doesn´t exist (STM32L476 Nucleo)
Re: UART(4) doesn´t exist (STM32L476 Nucleo)
Nucelo-L476 firmware has only define UART2 default.
You may add these lines (from PYBV10) to mpconfigboard.h and recompile the firmware.
// UART config
#define MICROPY_HW_UART2_TX (pin_A2)
#define MICROPY_HW_UART2_RX (pin_A3)
#define MICROPY_HW_UART_REPL PYB_UART_2
#define MICROPY_HW_UART_REPL_BAUD 115200
#define MICROPY_HW_UART1_NAME "XB"
#define MICROPY_HW_UART1_TX (pin_B6)
#define MICROPY_HW_UART1_RX (pin_B7)
#define MICROPY_HW_UART2_RTS (pin_A1)
#define MICROPY_HW_UART2_CTS (pin_A0)
#define MICROPY_HW_UART3_NAME "YB"
#define MICROPY_HW_UART3_TX (pin_B10)
#define MICROPY_HW_UART3_RX (pin_B11)
#define MICROPY_HW_UART3_RTS (pin_B14)
#define MICROPY_HW_UART3_CTS (pin_B13)
#define MICROPY_HW_UART4_NAME "XA"
#define MICROPY_HW_UART4_TX (pin_A0)
#define MICROPY_HW_UART4_RX (pin_A1)
#define MICROPY_HW_UART6_NAME "YA"
#define MICROPY_HW_UART6_TX (pin_C6)
#define MICROPY_HW_UART6_RX (pin_C7)
Thanks a lot for your fast response. Do you know the reason why only UART2 is defined? If I am right, UART2 is the serial port for the ST-Link VCOM port? So there is no UART I could use for applications.
It maybe there are too many Nucleo boards with different MCU. You may modify mpconfigboard.h to customize your firmware.
