BLACK_F407VE: @micropython.native in frozen bytecode decorator build fails
ProudPagan
Post by ProudPagan » Tue Jun 04, 2019 4:48 am
This is for the BLACK_F407VE STM32F407VET6 board with MicroPython 1.11 (source at top of the tree).
I have used the @micropython.native decorator on the class methods that I have put in the ports/stm32/modules/
directory.
On trying a clean build, I encounter this error:
GEN build-BLACK_F407VE/frozen_mpy.c
  File "../../tools/mpy-tool.py", line 864, in <module>
    main()
  File "../../tools/mpy-tool.py", line 852, in main
    raw_codes = [read_mpy(file) for file in args.files]
  File "../../tools/mpy-tool.py", line 852, in <listcomp>
  File "../../tools/mpy-tool.py", line 720, in read_mpy
    return read_raw_code(f, qstr_win)
  File "../../tools/mpy-tool.py", line 699, in read_raw_code
    raw_codes = [read_raw_code(f, qstr_win) for _ in range(n_raw_code)]
  File "../../tools/mpy-tool.py", line 699, in <listcomp>
  File "../../tools/mpy-tool.py", line 666, in read_raw_code
    off = read_uint(f, qstr_win)
  File "../../tools/mpy-tool.py", line 575, in read_uint
    b = read_byte(f, out)
  File "../../tools/mpy-tool.py", line 569, in read_byte
    out.append(b)
AttributeError: 'QStrWindow' object has no attribute 'append'
../../py/mkrules.mk:118: recipe for target 'build-BLACK_F407VE/frozen_mpy.c' failed
make: *** [build-BLACK_F407VE/frozen_mpy.c] Error 1
make: *** Deleting file 'build-BLACK_F407VE/frozen_mpy.c'
Without the decorator, build succeeds and I have a working .hex running fine on the board (but performance
sucks, hence the need for speed).
What am I doing wrong?
PP
Re: BLACK_F407VE: @micropython.native in frozen bytecode decorator build fails
Post by jimmo » Tue Jun 04, 2019 5:44 am
Looks like a bug. I've raised https://github.com/micropython/micropython/issues/4829 with more info.
Unfortunately I don't understand the new native .mpy encoding well enough to send a PR.
Sorry I don't have a good workaround for you right now.
ProudPagan
Post by ProudPagan » Tue Jun 04, 2019 1:19 pm
Thanks, jimmo.
Does anyone know how much speedup I can expect when using viper and native emitters w.r.t. pure Python for integer and string
operations?
PP
ProudPagan
Post by ProudPagan » Tue Jun 04, 2019 3:20 pm
I just picked up the fix to mpy-tool.py that Damien committed (https://github.com/micropython/micropython/issues/4829)
The build proceeds with warnings, but now my function (__truediv__) doesn't work -- I get this message:
TypeError: function missing required positional argument #31
I see these build warnings -- so I think there could be some other issue lurking somewhere:
build-BLACK_F407VE/frozen_mpy.c:20728:47: note: (near initialization for 'fun_data_mpap__lt_module_gt__mpap___truediv__')
build-BLACK_F407VE/frozen_mpy.c:20729:5: warning: excess elements in array initializer
     MP_QSTR___truediv__ & 0xff, MP_QSTR___truediv__ >> 8,
Post by jimmo » Tue Jun 04, 2019 10:20 pm
Can you post a follow-up to the bug?
That warning definitely sounds like it would be related to your problem.
Post by jimmo » Tue Jun 04, 2019 10:30 pm
operations?
It's hard to say because it depends so much on what the code is doing. So you've just got to measure it.
In one project where I used it quite a lot it made the difference between the project working and not working, but I got much bigger gains from restructuring the code (e.g. avoiding gc pressure, using memoryviews, algorithmic etc).
FYI I'm not sure how much native/viper affect string performance. (I've never looker, but perhaps mistakenly I've always assumed it was mostly about integer stuff).
ProudPagan
Post by ProudPagan » Wed Jun 05, 2019 5:28 am
Just did!
