How to use network.LAN on NUCLEO_F429
Posted: Tue Aug 13, 2019 11:25 am
by chg
either I am too stupid or there is no explanation how exactly to use the network interface on the mentioned nucleo.
I successfully compiled the latest micropython from github with
make BOARD=NUCLEO_F429ZI -j8 MICROPY_HW_ENABLE_ETH_RMII=1
and the autocompletion shows the existance of "network.LAN" on the REPL but i don't succedd with starting the LAN and requesting an IP address using DHCP.
Any example that helps me to get started?
Re: How to use network.LAN on NUCLEO_F429
Posted: Tue Aug 13, 2019 2:11 pm
by jimmo
Can you share your code that you're using to request a DHCP lease?
I don't have one of these boards, but I think it should be something like:
lan = network.LAN()
lan.active(True)
lan.ifconfig('dhcp')
# use lan.ifconfig() to wait for lease
Posted: Fri Aug 16, 2019 3:37 pm
by kcoelho
When I enter the command "network.LAN()" in the REPL prompt, the prompt itself shuts down.
Any ideas as to why this happens?
