Page 5 of 8
Re: WeAct STM32F411CEU6 black pill
Posted: Sat Dec 19, 2020 1:33 pm
by RobH
When I try to build the firmware version of today I get the messages as shown below.
How do I solve this?
boards/WEACT_F411CEU6/bdev.c:16:8: error: unknown type name 'mp_spiflash_cache_t'
16 | STATIC mp_spiflash_cache_t spi_bdev_cache;
boards/WEACT_F411CEU6/bdev.c:23:6: error: 'const struct _mp_spiflash_config_t' has no member named 'cache'
23 | .cache = &spi_bdev_cache,
boards/WEACT_F411CEU6/bdev.c:23:14: error: excess elements in struct initializer [-Werror]
boards/WEACT_F411CEU6/bdev.c:23:14: note: (near initialization for 'spiflash_config')
cc1: all warnings being treated as errors
Posted: Sat Dec 19, 2020 3:06 pm
by dhylands
The command help('modules') will show you the modules which are built into the firmware:
>>> help('modules')
__main__ micropython uasyncio/stream urandom
_onewire network ubinascii ure
_uasyncio onewire ucollections uselect
builtins pyb uctypes usocket
cmath stm uerrno ustruct
dht uarray uhashlib usys
framebuf uasyncio/__init__ uheapq utime
gc uasyncio/core uio utimeq
lcd160cr uasyncio/event ujson uzlib
lcd160cr_test uasyncio/funcs umachine
math uasyncio/lock uos
Plus any modules on the filesystem
Posted: Mon Dec 28, 2020 7:27 pm
by RDA
dhylands wrote: ↑Sat Dec 19, 2020 3:06 pm
>>> help('modules')
Thank you sir and sorry for not being able to give it a go earlier.
So unfortunately this did not get me any closer to my goal which is to get Little File System (either version) added to the board. Looking also at the micropython docs its says "other STM32" only FAT included in the fw.
I have been trying to look on how to get the build ton include the LFS to the fw but cant really find anything. Would be great if someone could tell where to start reading on adding modules and/or altering the build.
Posted: Sat Jan 02, 2021 10:19 pm
by Jeizoo
RobH wrote: ↑Sat Dec 19, 2020 1:33 pm
Use this fork (
https://github.com/jugnu-jethi/WeAct_F4 ... tTimeBuild) to compile with uP 1.13
Hope it helps.
Posted: Sun Jan 03, 2021 10:48 am
by rahmed
I am new to the forum as we as to Micro python but I did work with C, Pascal and microcontrollers in the past. I successfully built firmware for STM32F411CEU6 board based on the mcauser WEACT_F411CEU6 github link and I am able to download to black pill MCU and use it to develop some small projects.
I have now ordered two STM32F411CEU6 Version 3.0 with pre installed Winbond W25Q64 (8 MByte) and was trying to built firmware for the boards and I updated the following parameters in mpconfigboard.h file.
#define MICROPY_HW_ENABLE_INTERNAL_FLASH_STORAGE (0)
#define MICROPY_HW_SPIFLASH_SIZE_BITS (64 * 1024 * 1024)
With this changes/updates I am now following Errors and it abort the firmware built process, am I missing some modification in other files, Thanks in advance for your support
------------------Error -------------------------
CC boards/WEACT_F411CEU6/board_init.c
CC boards/WEACT_F411CEU6/bdev.c
make: *** [../../py/mkrules.mk:77: build-WEACT_F411CEU6/boards/WEACT_F411CEU6/bdev.o] Error 1
Posted: Sun Jan 03, 2021 11:23 am
by rahmed
Jeizoo,
I used your link and I am getting the following error
adc.h:50:29: error: 'LL_ADC_PATH_INTERNAL_VBAT' undeclared (first use in this function); did you mean 'HAL_ADC_ERROR_INTERNAL'?
adc_common->CCR &= ~LL_ADC_PATH_INTERNAL_VBAT;
adc.h:50:29: note: each undeclared identifier is reported only once for each function it appears in
make: *** [../../py/mkrules.mk:77: build-WeAct_F411CE/machine_adc.o] Error 1
make: *** Waiting for unfinished jobs....
Posted: Sun Jan 03, 2021 1:26 pm
by Jeizoo
rahmed wrote: ↑Sun Jan 03, 2021 11:23 am
Check that you pulled the
right branch of the git repo (myFix_FirstTimeBuild)
This error is fixed in the above branch with this in stm32f4xx_hal_conf.h
#ifdef HAL_ADC_MODULE_ENABLED
#include "stm32f4xx_hal_adc.h"
THIS LINE ----> #include "stm32f4xx_ll_adc.h"
#endif /* HAL_ADC_MODULE_ENABLED */
Posted: Sun Jan 03, 2021 5:01 pm
by stumin
If you're having problem compiling firmware for STM32F411CEU6 and getting these error:
then try inserting:
#define MICROPY_HW_SPIFLASH_ENABLE_CACHE (1)
in boards/WEACT_F411CEU6/mpconfigboard.h
I have it after MICROPY_HW_ENABLE_INTERNAL_FLASH_STORAGE
// 1 = use internal flash (512 KByte)
// 0 = use onboard SPI flash (4 MByte) Winbond W25Q32
Hopefully it will work for you.
Posted: Sun Jan 03, 2021 7:20 pm
by rahmed
Jeizoo wrote: ↑Sun Jan 03, 2021 1:26 pm
Jeizoo,
Thanks for the quick reply. You are right that I don't have the highlighted updates in stm32f4xx_hal_conf.h file. I need so guidance/help how to download the latest Branch using Git as tried to download the Zip file and update it manually but it gave me errors as I am assuming that there are object files in the overall package
Appreciate you support and Thanks in advance for the help.
Kind Regards
Rizwan
Posted: Sun Jan 03, 2021 8:07 pm
by RobH
@stumin: Thanks for the suggestion to add the #define for the SPI cache: I now have a working firmware V1.13-268!
One remark: the make works fine under Linux Mint 20.0, but produces error messages (different than the ones related to cache) under Linux Mint 20.1-beta. Presumably an issue of the beta.
It was because I forgot to install a prerequisite on my newly installed Mint 20.1:
sudo apt install gcc-arm-none-eabi
