Thanks for the answer with example, i guess the port for my F401CC (256 kb) doesn't support it, gonna wait for my F411CE boards.
WeAct STM32F411CEU6 black pill
Re: WeAct STM32F411CEU6 black pill
I'm quite new to MP and STM32, so please forgive me if my question is too trivial!
Is there a way to extend the allowed maximum firmware size during compile when I use W25Q128?
I figured out that I need to search around FLASH_TEXT and FLASH_FS... but I'm stuck here.
My reason:
I try to compile a FW with WIZNET5K and LWIP support and I try to freeze the MicroWebSrv2 module into it.
Without the MicroWebSrv2 it compiles fine, but as soon as I try to integrate it, I got the following error:
My reason:
make MICROPY_PY_WIZNET5K=5500 MICROPY_PY_LWIP=1 BOARD=WEACT_F411CEU6 -j2
LINK build-WEACT_F411CEU6/firmware.elf
arm-none-eabi-ld: build-WEACT_F411CEU6/firmware.elf section `.text' will not fit in region `FLASH_TEXT'
arm-none-eabi-ld: region `FLASH_TEXT' overflowed by 30536 bytes
make: *** [Makefile:669: build-WEACT_F411CEU6/firmware.elf] Error 1
Hello everyone! I have this "black pill" f401ccu6 board. I bought it a long time ago and haven't used it, but I now need a board on which to put mycropython. On the back of the board it says "weact v2.0". I wasn't able to find an image for it, the official github page has documentation and images for f401ceu6. Any way to get micropython running on this?
This is apparently an update of this variant of the Black Pill:
https://stm32-base.org/boards/STM32F401 ... -Pill-V1.2
You need to compile your own firmware for this variant of the Black Pill.
You should be able to use this board definition from WeACT:
https://github.com/YXZhu/micropython/tr ... Act_F401CC
You can follow the instructions for mcausers board definition for the STM32F411CEU6:
https://github.com/mcauser/WEACT_F411CEU6
And adapt them where necessary.
Hth, Chris
Hth, Chris
Ok so I tried doing just that, got the board definitions and tried building but I get a bunch of errors and compilation stops:
and so on...
In file included from ./mpconfigport.h:31,
from ../../py/mpconfig.h:62,
from ../../lib/oofatfs/ffconf.h:30,
from ../../lib/oofatfs/ff.h:33,
from ../../lib/oofatfs/ff.c:28:
boards/WeAct_F401CC/mpconfigboard.h:19: error: "MICROPY_VFS_FAT" redefined [-Werror]
19 | #define MICROPY_VFS_FAT (0)
<command-line>: note: this is the location of the previous definition
cc1: all warnings being treated as errors
from ../../lib/oofatfs/ffunicode.c:26:
Hi bartag,
Did you modify your mpconfigboard.h file?
I tried your line:
without WIZNET and it compiled for me using arm-none-eabi-gcc-4.9.3 on a 32 bit machine. Thanks for the hint ... I have been messing around in the mpconfigboard files ... this looks an easier way to do it.
I would like to build in support for PPP as well so I can try to talk to a Huawei 3G dongle. Any suggestions?
Thanks,
Dave
I tried your line:
make MICROPY_PY_LWIP=1 BOARD=WEACT_F411CEU6 -j2
Thanks,
Dave
bartag,
I tried building with the W25Q32 by changing line 9 in mpconfigboard.h and got the same problem. I think there are some hints earlier in this thread so I am off to re-read them.
Tried the other fork here:
and got the same error. I noticed that the lines:
were not in his mpconfigboard.h file. Even including them made no difference.
Off to find who generates the FLASH_TEXT message.
Both firmware.map and stm32f411.ld have the name FLASH_TEXT in them, the first length 0x00060000 (393,216) and the second 384K.
Doesn't something need to change these numbers when you use bigger flash?
git clone https://github.com/jugnu-jethi/WeAct_F411CE-MicroPython.git WeAct_F411CE
#define MICROPY_HW_ENABLE_INTERNAL_FLASH_STORAGE (0)
#define MICROPY_HW_SPIFLASH_ENABLE_CACHE (1)
