Porting micropython to STM32Nucleo-F4
Re: Porting micropython to STM32Nucleo-F4
Post by dhylands » Thu Aug 27, 2015 12:13 am
I happen to have a 401NUCLEO board sitting on my shelf, so I cloned your repository and flashed using stlink.
I was able to reproduce your results. I tried A0 thru A10 (skipping A2/A3 since those are are REPL UART) and on all of them except A9, the pullup seemed to work fine.
Since A9 is used for VBUS sensing, I theorized that some USB circuitry was being connected.
I modified your mpconfigbord.h file and commented out the
#define MICROPY_HW_USB_VBUS_DETECT_PIN (pin_A9)
line, but that didn't seem to make any difference.
You may need to completely disable the USB device completely (which IIRC is non-trivial with the current codebase) in order to get the internal A9 pullup to behave properly.
mike38
Post by mike38 » Thu Aug 27, 2015 8:04 am
thanks a lot for your tests. Now I know it is not a mistake or a hardware failure.
I will add an external pull up or modify my circuit to not use A9.
