Need some help setting up UART5
gradoj
Post by gradoj » Sat May 30, 2015 8:02 pm
I am trying to get UART 5 up and running on a custom board. I've made a couple of modifications but when I .read it always returns with no data and when I .write nothing goes out on uart 5.
If anyone can point out where I've gone wrong I'd appreciate it. Is there a way to query the pins to see if they are setup for their alternate function?
mpconfigboard.h
#define MICROPY_HW_UART5_PORT (GPIOC)
#define MICROPY_HW_UART5_PINS (GPIO_PIN_12)
uart.c in uart_init2 I tried with the commented lines in and out
#if defined(UART5) && defined(MICROPY_HW_UART5_PORT) && defined(MICROPY_HW_UART5_PINS)
case PYB_UART_5:
	UARTx = UART5;
        irqn = UART5_IRQn;
        GPIO_AF_UARTx = GPIO_AF8_UART5;
        GPIO_Port = MICROPY_HW_UART5_PORT;
        GPIO_Pin = MICROPY_HW_UART5_PINS;
	__UART5_CLK_ENABLE();
	GPIO_InitTypeDef GPIO_InitStructure;
	GPIO_InitStructure.Pin = GPIO_PIN_2;
	//GPIO_InitStructure.Speed = GPIO_SPEED_HIGH;
	//GPIO_InitStructure.Mode = GPIO_MODE_AF_PP;
	//GPIO_InitStructure.Pull = GPIO_PULLUP;
	GPIO_InitStructure.Alternate = GPIO_AF_UARTx;
	HAL_GPIO_Init(GPIOD, &GPIO_InitStructure);
break;
#endif
and in uart.c deinit
#if defined(UART5)
    } else if (uart->Instance == UART5) {
        HAL_NVIC_DisableIRQ(UART5_IRQn);
        __UART5_FORCE_RESET();
        __UART5_RELEASE_RESET();
        __UART5_CLK_DISABLE();
#endif
gradoj
Re: Need some help setting up UART5
Post by gradoj » Sat May 30, 2015 8:36 pm
It looks like those pins are not getting set to their alternate functions:
>>> a=pyb.Pin.board.PD2
>>> b=pyb.Pin.board.PC12
>>> a
Pin(Pin.cpu.D2, mode=Pin.IN)
>>> b
Pin(Pin.cpu.C12, mode=Pin.IN)
>>> a.af()
0
>>> b.af()
0
>>> a.af_list()
[Pin.AF2_TIM3, Pin.AF8_UART5]
>>> b.af_list()
[Pin.AF6_SPI3, Pin.AF7_USART3, Pin.AF8_UART5]
Post by dhylands » Sat May 30, 2015 9:04 pm
Your code seems to have the line which sets the alternate function commented out. In particular:
You really should initialize all of the fields, otherwise they get random values off the stack.
gradoj
Post by gradoj » Sun May 31, 2015 3:37 am
I put the commented out lines back in but the pins still do not get configured for their alternate function. It appears something isn't working in the new code I added to initialize UART5. When I configured the pins manually for their alternate function of uart5 and send bytes to that uart the REPL stops responding. Any strategies on debugging something like this?
Damien
Site Admin
Post by Damien » Sun May 31, 2015 6:55 am
A few things to check:
1. You need to define both the RX and TX pins in the MICROPY_HW_UART5_PINS macro.
2. You will need to add a UART5 irq handler in stm32f4xx_it.c.
3. You need to create and instance of the UART to set it up: pyb.UART(5, 9600).
gradoj
Post by gradoj » Sun May 31, 2015 7:09 am
1. tx and rx pins for uart5 are on different ports PC12 and PD12. I didnt see how I could use the existing macros. That is why I hardcoded the one pin in uart.c init for now. This may be messing something up?
2. I missed the irq handler. Thanks
3. I can send and receive on other uart ports so pretty sure im using it correctly
Damien
Site Admin
Post by Damien » Sun May 31, 2015 7:52 am
Note that PD2 is used as the SD card CMD pin, so the SD card will need to be disabled.
Here is what I get for UART(4):
>>> pyb.UART(4, 9600)
UART(4, baudrate=9600, ...)
>>> pyb.Pin.board.X1
Pin(Pin.cpu.A0, mode=Pin.AF_PP, pull=Pin.PULL_UP, af=Pin.AF8_UART4)
>>> pyb.Pin.board.X2
Pin(Pin.cpu.A1, mode=Pin.AF_PP, pull=Pin.PULL_UP, af=Pin.AF8_UART4)
gradoj
Post by gradoj » Sun May 31, 2015 6:32 pm
I was assuming from the af() that the pins were not in alternative function mode but it looks like they are. What does the af() function tell me?
>>> import pyb
>>> pyb.UART(5,115200)
UART(5, baudrate=115384, bits=8, parity=None, stop=1, timeout=1000, timeout_char=0, read_buf_len=64)
>>> pyb.Pin.board.PD2
Pin(Pin.cpu.D2, mode=Pin.AF_PP, pull=Pin.PULL_UP, af=Pin.AF8_UART5)
>>> pyb.Pin.board.PC12
Pin(Pin.cpu.C12, mode=Pin.AF_PP, pull=Pin.PULL_UP, af=Pin.AF8_UART5)
I don't see anything come out the uart with the write command. The read returns nothing like it should but as soon as I send a character to UART5 the REPL(which is on UART1) stops responding.
>>> a=pyb.UART(5,115200)
>>> a.write('asdf')
4
>>> a.read()
b''
Post by dhylands » Sun May 31, 2015 7:04 pm
The Pin.af() functions tells you the currently configured alternate function for the pin.
But the af() is only meaningful when Pin.mode() reports one of pyb.Pin.AF_PP or pyb.Pin.AF_OD. For all other modes, what af() reports is irrelevant.
I wrote a little script which you can find in the examples directory called pins.py. If you copy pins.py and the pins_af.py (from the stmhal/build-PYBV10 directory for your board) onto the pyboard and then from the pyboard REPL do this:
>>> import pins
>>> pins.pins()
X1         IN
X2         IN
X3         IN
X4         IN
X5         IN
X6         IN
X7         IN
X8         IN
X9         IN
X10        IN
X11        IN
X12        IN
X17        IN     PULL_UP
X18        IN
X19        IN
X20        IN
X21        IN
X22        IN
Y1         AF_PP  PULL_UP 8: USART6_TX
Y2         AF_PP  PULL_UP 8: USART6_RX
Y3         IN
Y4         IN
Y5         IN
Y6         IN
Y7         IN
Y8         IN
Y9         IN
Y10        IN
Y11        IN
Y12        IN
SW         IN     PULL_UP
LED_RED    OUT_PP
LED_GREEN  OUT_PP
LED_YELLOW OUT_PP
LED_BLUE   AF_PP          2: TIM3_CH1
MMA_INT    IN
MMA_AVDD   OUT_PP
SD_D0      AF_PP  PULL_UP 12
SD_D1      AF_PP  PULL_UP 12
SD_D2      AF_PP  PULL_UP 12
SD_D3      AF_PP  PULL_UP 12
SD_CMD     AF_PP  PULL_UP 12
SD_CK      AF_PP  PULL_UP 12
SD         IN     PULL_UP
SD_SW      IN     PULL_UP
USB_VBUS   IN
USB_ID     AF_OD  PULL_UP 10
USB_DM     AF_PP          10
USB_DP     AF_PP          10
Basically it reports the current configuration for each pin.
gradoj
Post by gradoj » Sun May 31, 2015 8:34 pm
Thanks. Pins.py will be a handy little script. I forgot to mention that I have disabled the SD card as one of the UART5 pins overlaps with it so I have no external filesystem for now.
I guess I ran .af() before I initialized the uart before and got fooled into thinking the alternate function wasn't setup properly.
>>> pc12=pyb.Pin.board.PC12
>>> pc12
>>> pc12.af()
0
>>> u5=pyb.UART(5,115200)
>>> u5
>>> pc12
>>> pc12.af()
8
So this is strange. It seems the uart5 is setup correctly but I cannot get anything out of it and if I write anything in to it something seems to crash.
