[PCA10028/NRF51] - does the I2C work in 1.11?
bgolab
Post by bgolab » Tue Dec 03, 2019 4:27 pm
Has anyone tested the I2C on nrf51 running MicroPython 1.11?
Tested both:
i2c=I2C(-1, scl=Pin(1), sda=Pin(0))
i2c.scan()
and
i2c=I2C(0, scl=Pin(1), sda=Pin(0))
i2c.scan()
[9, 11, 13, 15, 17, 19, 21, 23, 25, 27, 29, 31, 33, 35, 37, 39, 41, 43, 45, 47, 49, 51, 53, 55, 57, 59, 61, 63, 65, 67, 69, 71, 73, 75, 77, 79, 80, 81, 82, 83, 84, 85, 86, 87, 89, 91, 93, 95, 97, 99, 101, 103, 105, 107, 109, 111, 113, 115, 117, 119]
The I2C is working on STM32 board.
The pull up resistors are fine.
Bogdan
bgolab
Re: [PCA10028/NRF51] - does the I2C work in 1.11?
Post by bgolab » Tue Dec 03, 2019 7:30 pm
Just flashed pyboard with 1.11 and I2C works with the same I2C module:
>>> from machine import I2C, Pin
>>> i2c=I2C(1)
>>> i2c.scan()
[60, 76]
bgolab
Post by bgolab » Tue Dec 03, 2019 8:50 pm
Problem solved!
- I looks like the scan shows too many addresses - whereas the pyboards does it right - see the previous post.
- only option '0' works fine; the '-1' shows nothing if it comes to scanning
>>> MicroPython v1.11-611-g7f24c2977-dirty on 2019-12-02; PCA10028 with NRF51822
>>> i2c=I2C(0, scl=4, sda=3)
>>> i2c.scan()
[9, 11, 13, 15, 17, 19, 21, 23, 25, 27, 29, 31, 33, 35, 37, 39, 41, 43, 45, 47, 49, 51, 53, 55, 57, 59, 60, 62, 64, 66, 68, 70, 72, 74, 76, 78, 80, 82, 84, 86, 88, 90, 92, 94, 96, 98, 100, 102, 104, 106, 108, 110, 112, 114, 116, 118]
>>> import ssd1306
>>> oled=ssd1306.SSD1306_I2C(128,32,i2c,60)
>>> oled.text('ala', 1, 1, 1)
>>> oled.show()
Post by pythoncoder » Wed Dec 04, 2019 9:40 am
If software I2C (-1 arg) isn't working on that port perhaps you should raise an issue. I'm puzzled by the number of addresses returned by your scan. Why so many when the Pyboard returns only two?
bgolab
Post by bgolab » Wed Dec 04, 2019 9:46 am
Yes, it's weird.
I am mostly C developer for STM32 boards. And always implement a scan capability - these modules (OLED, FRAM) worked wine with my software.
Started playing with MicroPython on nrf51 and came across this strange issue (the scan behavior).
Then switched for a test to pyboard as this board seems to be matured.
It looks like both modules have proper pull ups (I looked at PCB without measuring the resistance + my C programs wok reliably + MicroPython and OLED module work fine).
It looks like a timing issue only for the I2C scan.
I cave a logic analyser (Saleae) to theoretically I could look at the I2C timing & response but in this week.
