New STM32H743VIT6 dev boards
mcauser
Re: New STM32H743VIT6 dev boards
Post by mcauser » Thu Feb 20, 2020 11:13 pm
I can replicate the problem now.
It seems I'm missing these PPL3 defines (lifted from NUCLEO_H743ZI/mpconfigboard.h)
// The USB clock is set using PLL3
#define MICROPY_HW_CLK_PLL3M (4)
#define MICROPY_HW_CLK_PLL3N (120)
#define MICROPY_HW_CLK_PLL3P (2)
#define MICROPY_HW_CLK_PLL3Q (5)
#define MICROPY_HW_CLK_PLL3R (2)
Unlike the NUCLEO board with it's 8MHz HSE, this board has a 25MHz HSE, which means the above values will need tweaking to match.
I did find this is one of the C examples that shipped with the board.
Stm32_Clock_Init(160,5,2,4) // 400MHz
Stm32_Clock_Init(u32 plln, u32 pllm, u32 pllp, u32 pllq)
Not sure how it translates to MICROPY defines.
I need to get my hands on that graphical clock calculator tool you mentioned @jimmo
Post by OutoftheBOTS_ » Fri Feb 21, 2020 10:26 pm
First I would check if this board does in fact have a 25MHz crystal as Ihave brought these cheap boards from China with advertised 25MHz crystal but then to find all my timing for my programs were out because it really had a 8MHz crystal and once I change the clock setup to suit a 8MHz crystal then all my timing were correct.
I check the freq of the crystal my setting the MCO to output the HSE then put it on my scope.
I tried to use cubeMX to setup this MCU but ST haven't yet added all the setup for this MCU to cubeMX yet but I would suggest checking out OpemMV project as they use this MCU with micro python and will have all the setup sorted
zaord
Post by zaord » Tue Mar 03, 2020 6:38 pm
Hi here !
Did you had any solution to solve the problem ?
Best regards :)
Ewen
abenragel
Post by abenragel » Sat Mar 21, 2020 8:43 pm
Received two of these boards today and put one under the microscope. Seems indeed to be a 25 MHz crystal.
I would really like to insert the image from my microscope here - if anybody could tell me how to to that ?
abenragel
Post by abenragel » Tue Mar 24, 2020 7:54 pm
I think that I managed to fix the missing factors of the clock tree.
FW builds now, but no repl at the usb port.
I think It could be reconfigured so that the repl is on one of the Uarts.
However, I would prefer to have it on usb - any idea what I forgot in the config ?
If you want to check out, find the configuration here:
https://bitbucket.org/jstoefer/devebox_h743/src/master/
Cheers,
Jan
zaord
Post by zaord » Fri Mar 27, 2020 10:38 am
Do you wants I try to compile to see if I get any errors ?
For pictures, you need to upload a picture over the internet and to put the link here ... (imageshare, drive, ftp , ..;)
Thanks a lot !
Best
holberg
Post by holberg » Mon Jun 01, 2020 4:52 pm
Cheers,
Jan
Hi all
REPL on USB runs fine here , but the SDCARD is not visible, any Ideas?
Regards
Holger
Post by dhylands » Mon Jun 01, 2020 5:20 pm
As for the sdcard, I'd check to see if its wired up the same as the pyboard (sdcards can be implemented using SDIO or various widths of SPI bus). Also make sure that the "Card Detect" setting matches your actual board wiring.
holberg
Post by holberg » Tue Jun 02, 2020 6:50 am
I use the board definition from "mcauser" and add the PLL3 as of this thread. REPL works. The pin definition in the csv is ok. Is there anything else ? Clock ? AF ? todo
holberg
Post by holberg » Tue Jun 02, 2020 2:48 pm
Found. SDCARD was not enable. Works now :)
