NRF USB CDC Configurations
devnull
Post by devnull » Mon Jan 06, 2020 10:20 am
Does anyone know, for the NRF devices, other than connecting D+, D-, VBUS and Ground from USB cable and making the following changes in the mpcconfigboard.h, are there any other settings / connections to make CDC work on the NRF ??
is there any additional USB firmware that needs to be flashed to the device as well as the bluetooth and applications hexes ?
#define MICROPY_HW_USB_CDC            (1)
// UART config
#define MICROPY_PY_MACHINE_UART       (0)
As after doing this the usb device is not being recognized.
devnull
Re: NRF USB CDC Configurations
Post by devnull » Fri Jan 10, 2020 9:07 am
Ping....
Anybody have any suggestions about this ???
As the NRF52840 pca10059 has bluetooth and BT, it must be possible and the NRF device has the necessary connections for USB connections ?!
devnull
Post by devnull » Sat Jan 11, 2020 10:40 am
@jimmo - any idea about this ???
Post by jimmo » Sat Jan 11, 2020 2:02 pm
Sorry I haven't used USB on the NRF (usb support was added after I last used that particle xenon board i mentioned).
I can only suggest really generic stuff like looking at dmesg output when you connect it. Also without schematics for that module I don't know if you need any additional circuitry on the D+ / D-. Also does the module include built-in voltage regulation (i.e. can it be safely powered by 5V on Vbus?)
Might be worth following up on pr 5112?
