Boot time is 10 seconds for a NUCLEO_L452RE build
Posted: Mon Jan 20, 2020 12:09 am
by RWLTOK
I built V1.12 for the NUCLEO_L452RE board. When I reset the board, it is nearly 10 seconds before a promt appears. I checked this with a logic analyzer to prove that it was not a delay from WinDoz. Thoughts anyone? For what it's worth, I used whatever compiler you get with a apt-get install gcc-arm-none-eabi on Ubuntu 18.04 and not the latest version 9 that came out last Novemer from ARM Ltd.
MicroPython v1.12-68-g3032ae115 on 2020-01-19; NUCLEO-L452RE with STM32L452RE
Rich
PS: With the same build environment, I created an image for the PYBV11. Here is the output. It responded to a reset in the normal quick time.
MicroPython v1.12-68-g3032ae115 on 2020-01-19; PYBv1.1 with STM32F405RG
Re: Boot time is 10 seconds for a NUCLEO_L452RE build
Posted: Mon Jan 20, 2020 12:19 am
by RWLTOK
Here is some additional information:
~/micropython/ports/stm32/boards$ diff NUCLEO_L452RE/stm32l4xx_hal_conf.h PYBV11/stm32f4xx_hal_conf.h
5,6c5,6
< #ifndef MICROPY_INCLUDED_STM32L4XX_HAL_CONF_H
< #define MICROPY_INCLUDED_STM32L4XX_HAL_CONF_H
> #ifndef MICROPY_INCLUDED_STM32F4XX_HAL_CONF_H
> #define MICROPY_INCLUDED_STM32F4XX_HAL_CONF_H
8c8
< #include "boards/stm32l4xx_hal_conf_base.h"
> #include "boards/stm32f4xx_hal_conf_base.h"
11c11
< #define HSE_VALUE (8000000)
> #define HSE_VALUE (12000000)
13,14c13
< #define EXTERNAL_SAI1_CLOCK_VALUE (48000)
< #define EXTERNAL_SAI2_CLOCK_VALUE (48000)
> #define EXTERNAL_CLOCK_VALUE (12288000)
20c19
< #endif // MICROPY_INCLUDED_STM32L4XX_HAL_CONF_H
> #endif // MICROPY_INCLUDED_STM32F4XX_HAL_CONF_H
rich@poseiden:~/micropython/ports/stm32/boards$
Posted: Mon Jan 27, 2020 10:01 am
by chrismas9
I just updated my build to latest, rebuilt mpy-cross, updated submodules and built NUCLEO_L452RE using WSL. the NUCLEO board boots immediately. I am using gcc 9.2.1 from ARM and WSL/UBUNTU 16.04.
>>> MicroPython v1.12-96-gc3095b3 on 2020-01-27; NUCLEO-L452RE with STM32L452RE
Distributor ID: Ubuntu
Description:    Ubuntu 16.04.5 LTS
Release:        16.04
Codename:       xenial
arm-none-eabi-gcc (GNU Tools for Arm Embedded Processors 9-2019-q4-major) 9.2.1 20191025 (release) [ARM/arm-9-branch revision 277599]
Re: Boot time is 10 seconds for a NUCLEO_L452RE_P build
Posted: Sat Feb 15, 2020 4:02 pm
by RWLTOK
<scratching head> Ok... The ole "works on my machine". That is good to know. I am using an older compiler version and 18.03. Hmm. I actually have the NUCLEO_L452RE_P. This is the one with SMPS (low voltage core) support. I wonder if there is a different default clock speed. Even though I have it jumpered for 3.3V operation, I don't think the CPU knows that. Thanks for responding. I now have a place I can look for the cause.
I updated the subject to add the _P.
Rich
Posted: Mon Apr 20, 2020 8:10 pm
by rruf
Did you find a solution? I am having a similar problem here, although different chip: STM32F407VGT6 - also takes strangely long to boot up.
