Info for W600-PICO owner that want to use or experiment Mu 1.1.0.alpha.2
https://github.com/mu-editor/mu/issues/1052
On github I have opened ( and closed after few days) the following. issue:
File System Navigator vs WinnerMicro W600-PICO board #1052
The software solution is shortly described below .
( With the attached modified microfs.py file and pyboard.py. - a modified solution by Volodymyr Shymanskyy to enable Adafruit ampy to work by raw REPL with W600 boards - we can have all the elements to follow the explanation )
For my trials, the default raw_on(serial) function in microfs.py, has been substituted by the enter_raw_repl(serial) cloned from a modified ( for W600 boards) pyboard.py file (from my search the author should be Volodymyr Shymanskyy).
I only have adapted the enter_raw_repl() function to the microfs.py code context ( for example substituting the PyboardError with IOError, etc, ...) and :
a- In the microfs.py ls(serial) function , to remove the spurious b"\n>OK" I have added after the line:
out, err = execute(["import os", "print(os.listdir())"], serial)
the following instruction:
out = out.lstrip(b"\n>OK")
b- and in :
execute(commands, serial=None)
I have commented the raw_on(serial) and added the cloned enter_raw_repl(serial ):
#raw_on(serial) # default raw REPL function
enter_raw_repl(serial) # from pyboard.py modified by WS
( see the attachments )
Remarks: This is only a positive trial , the optimal code solution can be surely different)
I have also tested the solution with an ESP8266 board without nothing any functionality difference.
On the WEB, to visually show what I have described, I have placed. the following short video:
W600-PICO vs Mu 1.1.0.alpha.2. Micropython Editor
That's all.
W600-PICO vs Mu 1.1.0.alpha2 editor
- 5_Mu_Files_W600-PICO_a.PNG (104.1 KiB) Viewed 4204 times
- 3_Mu_raw_repl_in REPL_shell.png (134.87 KiB) Viewed 4204 times
- 2_Mu_Files_OSError_3.PNG (105.56 KiB) Viewed 4204 times
Re: W600-PICO vs Mu 1.1.0.alpha2 editor
Just to specify that the video showing the code modifications to microfs.py module is W600-PICO vs Mu 1.1.0.alpha.2 & code
From one of my previous post on this forum:
viewtopic.php?f=12&t=7652&start=10
Re: Wemos W600-Pico
Post Mon Apr 13, 2020 6:31 am
A precondition to work minimizing the problems with uPyCraft is of flashing the last micropython firmware( file wm_w600.fls) for W600-PICO in place of the default one on the board, following the Shymanskyy procedure. In the same dir where we have the w600tool.py copy the last micropython firmware file wm_w600.fls and :
1st - erase the flash with (**):
python ./w600tool.py -p COM15 -b 115200 -e
2nd - upload the fls file:
python ./w600tool.py -p COM15 -b 115200 --upload wm_w600.fls
(**) or with the w600tool.exe
To download un new firmware we need to use the Volodymyr Shymanskyy w600tool ( Python or Windows version) that can be downloaded from github.
Note:
COMxx with Windows OS
/dev/ttyUSB0 with Linux
was suggested before to work with uPyCraft.
Well, the same thing must be done to avoid any problem with Mu editor.
I want to remark this point because one w600-pico user, watching on the WEB the video(*) mentioned in my previous post (W600-PICO vs Mu 1.1.0.alpha.2. Micropython Editor) ask me:
"Hi Federico,
Could you kindly explain in a bit more detail how to implement the modifications?
Thank you.
Regards,
Hxxxx"
Hxxxx, after to have modified the microfs.py module :
I have flashed the firmware several times on different boards leading to the same results.
I also notice strange files ( libraries ??) on the board.
I have included screenshots.
If you have any suggestions please let me know "
And the screenshot that I received ( see the attachment Screenshot_mu.png) shows me the same image that I have on uPyCraft before to have reflashed the board - shortly the same issue.
This is the reason of this new post regarding the use of Mu 1.1.0.alpha.2 micropyton editor vs W600-PICO.
After to have erased the flash and flashed the last update micropython release that can be downloaded. from:
https://github.com/robert-hh/Shared-Stu ... m_w600.fls
( my persomal thanks to robert-hh to have included the User free flash size in the ls command)
I received the following message :
Hi Federico,
Good results thanks to your help.
The latest Firmware definitely works better.
You are absolutely right, I needed to erase the memory with : python ./w600tool.py -p /dev/ttyUSB0 -e
before flashing with the new firmware.
I can finally start to play with some code ...
Many thanks to you for your patience and explanations.
Have a great Sunday,
Regards,
Hxxxx
In the Hxxxx attachments the results after to have reflashed the board.
(*)And for this reason I posted a more detailed video on the WEB - the second one mentioned in my previous post, to make more clear what must be done to correctly work with Mu micropyt
Re: Wemos W600-Pico
Note:
"Hi Federico,
Thank you.
Regards,
Hxxxx"
Hi Federico,
Regards,
Hxxxx
- yeah_4.png (174.7 KiB) Viewed 4099 times
- yeah_3.png (91.95 KiB) Viewed 4099 times
- Screenshot_mu.png (157.26 KiB) Viewed 4099 times
I have update the fls files for the W600 at this place: https://github.com/robert-hh/Shared-Stuff. Compared to the May 26 version, there are a few changes, listed in the commit description. For more details, the repository branch is here: https://github.com/robert-hh/micropython/tree/w60x
A new thank you roberthh for your timely clarification and mainly for the contribution you make to the micropython community.
Thanks, but that's not only me. Most of the work had been done by @wdyichen, who made the initial port. And the latest changes to the machine.pin module have been contributed by @etobi. I see my part as just smoothing some rough edges.
I fully share your observation. My thanks, although indirect, go to all those who on stage or behind the scenes help us with their work
