STM32F407VET6 lcd i2c
bellad
Post by bellad » Wed Aug 26, 2020 1:03 pm
i try adapt script for my stm32 but :
lcd = I2cLcd(i2c, DEFAULT_I2C_ADDR, 2, 16)
File "esp8266_i2c_lcd.py", line 52, in __init__
OSError: [Errno 19] ENODEV
>>> print(i2c.scan())
[39]
esp8266_i2c_lcd.py
"""Implements a HD44780 character LCD connected via PCF8574 on I2C.
This was tested with: https://www.wemos.cc/product/d1-mini.html"""
from lcd_api import LcdApi
from machine import I2C
from time import sleep_ms
i2c = I2C(sda=Pin('B10'), scl=Pin('B11'))
# The PCF8574 has a jumper selectable address: 0x20 - 0x27
DEFAULT_I2C_ADDR = 0x39
# Defines shifts or masks for the various LCD line attached to the PCF8574
MASK_RS = 0x01
MASK_RW = 0x02
MASK_E = 0x04
SHIFT_BACKLIGHT = 3
SHIFT_DATA = 4
class I2cLcd(LcdApi):
"""Implements a HD44780 character LCD connected via PCF8574 on I2C."""
def __init__(self, i2c, i2c_addr, num_lines, num_columns):
self.i2c = i2c
self.i2c_addr = i2c_addr
self.i2c.writeto(self.i2c_addr, bytearray([0]))
sleep_ms(20) # Allow LCD time to powerup
# Send reset 3 times
self.hal_write_init_nibble(self.LCD_FUNCTION_RESET)
sleep_ms(5) # need to delay at least 4.1 msec
sleep_ms(1)
sleep_ms(1)
# Put LCD into 4 bit mode
self.hal_write_init_nibble(self.LCD_FUNCTION)
sleep_ms(1)
LcdApi.__init__(self, num_lines, num_columns)
cmd = self.LCD_FUNCTION
if num_lines > 1:
cmd |= self.LCD_FUNCTION_2LINES
self.hal_write_command(cmd)
def hal_write_init_nibble(self, nibble):
"""Writes an initialization nibble to the LCD.
This particular function is only used during initialization.
byte = ((nibble >> 4) & 0x0f) << SHIFT_DATA
self.i2c.writeto(self.i2c_addr, bytearray([byte | MASK_E]))
self.i2c.writeto(self.i2c_addr, bytearray([byte]))
def hal_backlight_on(self):
"""Allows the hal layer to turn the backlight on."""
self.i2c.writeto(self.i2c_addr, bytearray([1 << SHIFT_BACKLIGHT]))
def hal_backlight_off(self):
"""Allows the hal layer to turn the backlight off."""
def hal_write_command(self, cmd):
"""Writes a command to the LCD.
Data is latched on the falling edge of E.
byte = ((self.backlight << SHIFT_BACKLIGHT) | (((cmd >> 4) & 0x0f) << SHIFT_DATA))
byte = ((self.backlight << SHIFT_BACKLIGHT) | ((cmd & 0x0f) << SHIFT_DATA))
if cmd <= 3:
# The home and clear commands require a worst case delay of 4.1 msec
sleep_ms(5)
def hal_write_data(self, data):
"""Write data to the LCD."""
byte = (MASK_RS | (self.backlight << SHIFT_BACKLIGHT) | (((data >> 4) & 0x0f) << SHIFT_DATA))
byte = (MASK_RS | (self.backlight << SHIFT_BACKLIGHT) | ((data & 0x0f) << SHIFT_DATA))
esp8266_i2c_lcd-test.py
from time import sleep_ms, ticks_ms
from machine import I2C, Pin
from esp8266_i2c_lcd import I2cLcd
def test_main():
"""Test function for verifying basic functionality."""
print("Running test_main")
#i2c = I2C(sda=Pin('B10'), scl=Pin('B11'))
lcd.putstr("It Works!\nSecond Line")
sleep_ms(3000)
lcd.clear()
count = 0
lcd.move_to(0, 0)
lcd.putstr("%7d" % (ticks_ms() // 1000))
sleep_ms(1000)
count += 1
if count % 10 == 3:
print("Turning backlight off")
lcd.backlight_off()
if count % 10 == 4:
print("Turning backlight on")
lcd.backlight_on()
if count % 10 == 5:
print("Turning display off")
lcd.display_off()
if count % 10 == 6:
print("Turning display on")
lcd.display_on()
if count % 10 == 7:
print("Turning display & backlight off")
lcd.backlight_off()
lcd.display_off()
if count % 10 == 8:
print("Turning display & backlight on")
lcd.backlight_on()
lcd.display_on()
bellad
Re: STM32F407VET6 lcd i2c
Post by bellad » Thu Aug 27, 2020 12:12 pm
ok i found , with other
to serve :
https://github.com/dork3nergy/lcd_2004
