board: tw-02 based on w600 wifi problem
serdio
Post by serdio » Thu Dec 24, 2020 7:06 am
Hello
The problem: I can't connect to WiFi as client but can start it as AP
What I do:
sta_if.active(True)
sta_if.scan()
Scan always return empty list
The same on wrapper function
import easyw600
easyw600.scan()  #Scanning Peripheral WiFi Network
but if I start AP it works, so I assume that radio module is working
import easyw600
easyw600.createap(ssid="w60x_softap", password=None) #create a soft ap
What may be a problem with starting wifi as client ( STA_IF mode)?
Thank you
Re: board: tw-02 based on w600 wifi problem
Post by Roberthh » Thu Dec 24, 2020 7:43 am
I can use STA mode. But I never called scan(). Instead I connect directly to a known AP. Does that work for you?
serdio
Post by serdio » Thu Dec 24, 2020 7:48 am
No, it doesn't. The same behavior was when I tried arduino port for this board. It's not connected to wifi as client.
Post by Roberthh » Thu Dec 24, 2020 9:36 am
easyw600.scan() works here. And connecting using easyw600.connect() too. And it always did. I have my local AP set up for WPA2. Maybe that is a problem.
Which firmware are you using?
serdio
Post by serdio » Thu Dec 24, 2020 10:12 am
    __            __
    /_/    \/    \_\
    WinnerMicro W600
MicroPython v1.10-284-g2eee4e2-dirty on 2019-11-08; WinnerMicro module with W600
Is there any other firmware for this board?
serdio
Post by serdio » Thu Dec 24, 2020 10:27 am
The same on
WinnerMicro W600
MicroPython v1.10-282-g6a9b3cb-dirty on 2019-09-17; WinnerMicro module with W600
from here https://docs.wemos.cc/en/latest/tutoria ... _w600.html
http://www.winnermicro.com/upload/1/edi ... 203932.zip
Post by Roberthh » Thu Dec 24, 2020 10:46 am
A few people have worked together to update the W600 firmware, remove a few bugs and make it more compatible to the MicroPython main thread, espcially for the Pin, I2C, SPI, utime and asyncio module. Some of the changes have been adopte by WinnerMicro in their Micropython repository, but the never published new binaries.
Some binary images for our branch can be found here: https://github.com/robert-hh/Shared-Stuff
I have to update them again.
The source tree for that is here: https://github.com/robert-hh/micropython/tree/w60x
It is mostly up-to-date.
serdio
Post by serdio » Thu Dec 24, 2020 10:57 am
connecting...
upysh is intended to be imported using:
from upysh import *
To see this help text again, type "man".
upysh commands:
clear, ls, ls(...), head(...), cat(...), newfile(...)
cp('src', 'dest'), mv('old', 'new'), rm(...)
pwd, cd(...), mkdir(...), rmdir(...)
No Wifi setting found
WinnerMicro W600
MicroPython v1.13-100-g3131a6859-dirty on 2020-09-18; WinnerMicro module with W600
Still not connected, but here I see new message "No Wifi setting found"
OK
# put system init code
# print("")
# print("    __            __")
# print("    \ \    /\    / /")
# print("     \ \  /  \  / /")
# print("      \ \/ /\ \/ / ")
# print("       \  /  \  /")
# print("       / /\  / /\ ")
# print("      / /\ \/ /\ \ ")
# print("     / /  \  /  \ \ ")
# print("    /_/    \/    \_\ ")
from upysh import *
    import wifi_config
    from easyw600 import *
    connect(wifi_config.WIFI_SSID, wifi_config.WIFI_PASSWD)
    ftpserver()
except:
    print("No Wifi setting found")
from pye_mp import pye
Post by Roberthh » Thu Dec 24, 2020 11:46 am
Sorry for the confusion. The _boot.py looks for a file called wifi_config.py with the content:
WIFI_SSID="<my_ssid>"
WIFI_PASSWD ="<my_ssid_passwd>"
Besides that WiFi should work. Maybe there is a problem with local AP's
serdio
Post by serdio » Thu Dec 24, 2020 1:33 pm
I measure current consumption of the board
On startup and idle mode -- 20.6ma
On network.connect(...) -- 25ma (for 10sec and return to idle) -- fail on "AP not found"
On easyw600.createap(...) -- 106ma
I check different AP's including hotspot on smartphone (2.4GHz)
So I think it just doesn't power on the radio module in client mode
