[STM32F429DISC] Pin is not defined
bogdansrb
Post by bogdansrb » Mon Jan 25, 2021 11:41 am
Greetings,
I've flashed micropython on my STM32F429 discovery board (the one with the LCD) and I get this error while trying to configure the pins:
>>> led = Pin(PG13, Pin.OUT)
NameError: name 'PG13' isn't defined
I've looked on the board definitions and the pin is indeed defined (https://github.com/micropython/micropyt ... 32F429DISC)
If it matters, I couldn't flash the normal way via dfu, so I converted the dfu file to hex using dfu file manager and then flashed the st link way. I can see the flash storage and connect to repl just fine.
Re: [STM32F429DISC] Pin is not defined
Post by jimmo » Tue Jan 26, 2021 1:01 am
When you use a named string with the machine.Pin constructor it needs to be a string. Also it's just G13 rather than PG13, so:
machine.Pin('G13', Pin.OUT)
You can also use
led = Pin.cpu.G13
led.init(Pin.OUT)
