[windows]no os.listdir and help
oyster
Post by oyster » Thu Feb 18, 2021 3:12 pm
I have compiled `micropython.exe` in msys2+mingw64. there is `os.ilistdir`, but no `os.listdir` which exists on esp8266
there is no `help` too
what is the step to enable/disable these specified functions on windows? Thanks
>>> import os
>>> dir(os)
['__class__', '__name__', 'remove', 'errno', 'getenv', 'ilistdir', 'mkdir', 'putenv', 'rename', 'rmdir', 'stat', 'system', 'unsetenv']
>>> help('modules')
NameError: name 'help' isn't defined
Re: [windows]no os.listdir and help
Post by jimmo » Fri Feb 19, 2021 3:41 am
I'm not entirely sure why the Unix port (and the Windows which is based on the Unix port) don't implement listdir. It would be relatively straightforward to add. See ports/unix/modos.c
This can be enabled in ports/windows/mpconfigport.h -- add:
#define MICROPY_PY_BUILTINS_HELP (1)
#define MICROPY_PY_BUILTINS_HELP_MODULES (1)
