Hello
I am having trouble with importing the ulab module on the EV3 after having compiled it as described at https://github.com/v923z/micropython-ulab#unix-port
I am able to run an interactive session at ulab/micropython/ports/unix where I can import ulab just fine, however outside of that interactive session I am unable to import ulab. I am using SSH (via Visual Studio Code) to access the EV3 and go through its file system. The tests that were included in the ulab repo (see https://github.com/v923z/micropython-ul ... ster/tests) also all fail because they're unable to import ulab. Any help is appreciated
[EV3] help with importing the ulab module
Re: [EV3] help with importing the ulab module
I'm not entirely sure how the EV3 works -- does it run Linux? Are you compiling MicroPython on the EV3 itself?ev3ulabenjoyer wrote: ↑Mon Mar 01, 2021 10:59 pmI am having trouble with importing the ulab module on the EV3 after having compiled it as described at https://github.com/v923z/micropython-ulab#unix-port
What's the difference between the interactive session that works and accessing it via SSH? How do you get an interactive session if not by SSH? (Sorry I don't know much about the EV3)
A microSD card which includes an installation of ev3dev (a Debian-based Linux OS see https://www.ev3dev.org/) is inserted into the EV3. MicroPython runs on top of ev3dev.
A "normal" interactive session (as in physically playing around with the EV3) allows you to run programs (that you've transferred to the EV3 from a PC) and change some basic settings through the ev3dev GUI on the EV3 device. By accessing the EV3 through SSH you're given a Bash shell to work with, which allows you to do much more (like cloning the ulab git repo and compiling it).
Nothing wrong with that, I'm learning myself
