VL53L1X ToF distance sensor - adapting to micropython
benjam
Post by benjam » Fri May 25, 2018 10:13 am
Hi guys,
I'm starting to experiment with the new VL53L1X sensor for which there is an Arduino library, and I'd like to port it to micropython.
https://github.com/sparkfun/SparkFun_VL ... no_Library
However I'm no expert and I have to learn a lot, and I'm using I2C to read/write to the correct registers.
It seems like someone wrote a library for the previous model of the sensor, the VL53L0X.
So if anyone is working on the new one please let me know as this would be useful.
Otherwise if I get somewhere I'm happy to share my code.
Ben
s-light
Re: VL53L1X ToF distance sensor - adapting to micropython
Post by s-light » Sun Sep 09, 2018 9:20 am
hi benjam,
did you started experimenting with this in MicroPython?
i have found a python librarie - but have not jet looked at what it needs to get this ported to MicroPython..
https://github.com/pimoroni/vl53l1x-python
and also what it takes to port it to Adafruit CircuitPython
- i think they have a different hardware-abstraction layer -
but have not read the Design Guide (https://circuitpython.readthedocs.io/en ... guide.html) yet..
i will post back here if i get something going..
sunny greetings
stefan
jickster
Post by jickster » Sun Sep 09, 2018 5:22 pm
I don’t have any of the mentioned hardware but I have done a lot with the C-layer of micropython.
Quote me if you need help with C-functionality.
devnull
Post by devnull » Wed Oct 10, 2018 4:50 am
The VL530LX predecessor thread is here: viewtopic.php?t=3358#p19605
@deshipu has created a library for the VL530LX but it does not appear to work for the VL531LX (https://bitbucket.org/thesheep/micropyt ... vl53l0x.py)
Tindie are selling these at only USD10.00 each (https://www.tindie.com/products/blkbox/ ... r-arduino/) which is where I got mine, which is incredible good value given they have a range of up to 4 meters, but I have been unable to get them to work !
csebe
Post by csebe » Fri Feb 14, 2020 2:52 pm
Has there been any updates? I'm using the same sensor with a v1.1 Pyboard. I watched the videos on how to write a C-wrapper in Micropython, but I don't know how I would have to write it when I have multiple .c and .h files. Could anyone suggest a way to get started?
Post by OutoftheBOTS_ » Fri Feb 14, 2020 11:09 pm
I have used this sensor with micropython but it was quite a while ago now. I did defiantly use
and it worked for me.
I looked through my videos and found a video that I made to send to someone that I was helping use the sensor. https://www.youtube.com/watch?v=jLUuA2j ... e=youtu.be
elschopi
Post by elschopi » Wed Sep 30, 2020 7:28 am
Hello everyone,
I know this is quite old, but I'm a bit out of ideas in getting this sensor to work.
The library which is linked in this thread is not available anymore, so I'm using https://github.com/uceeatz/VL53L0X
Now my problem is that this library is coming from a pycom wipy board, which I do not have. When trying on my ESP32, I get an error that tells me that the module 'Timer' doesn't have an attribute 'Chrono'.
From what I understand, it is only used to 'perform_single_ref_calibration', and used as a timer.
Is there a possibility to port the 'Chrono' part to ESP32? Or is that a specialty of the pycom boards?
Or, better yet, could someone provide me with the alternate library?
Best regards,
Chris
