Problem with the interrupt
Dieter.Tepe@live.de
Post by Dieter.Tepe@live.de » Fri Apr 09, 2021 8:03 pm
The Lib nextion_dieter.py
from micropython import const
import ustruct
COMMAND_PAGE_ID = 'page'
COMMAND_COMPONENT = 'ref'
COMMAND_CLICK = 'click'
COMMAND_STOP_REFRESH = 'ref_stop'
COMMAND_REFRESH_START = 'ref_star'
COMMAND_GET = 'get'
COMMAND_GET_PAGE = 'sendme'
COMMAND_VISIBLE = 'vis'
COMMAND_TOUCH_ENABLED = 'tsw'
COMMAND_ADD_DATA = 'add'
COMMAND_ADD_DATA_BULK = 'addt'
COMMAND_CLEAR = 'cle'
COMMAND_RESET = 'rest'
R_COMMAND_TOUCH_EVENT = const(0x65)
R_COMMAND_PAGE_ID = const(0x66)
R_COMMAND_TOUCH_COORDINATE = const(0x67)
R_COMMAND_TOUCH_COORDINATE_SLEEP_MODE = const(0x68)
R_COMMAND_STRING_DATA = const(0x70)
R_COMMAND_NUMERIC_DATA = const(0x71)
R_COMMAND_AUTO_SLEEP = const(0x86)
R_COMMAND_AUTO_WAKE_UP = const(0x87)
R_COMMAND_SYSTEM_STARTUP = const(0x88)
R_COMMAND_SD_UPGRADE = const(0x89)
R_COMMAND_TRANSPARENT_TRANSMIT_FINISHED = const(0xFD)
R_COMMAND_TRANSPARENT_TRANSMIT_READY = const(0xFE)
class Nextion_Dieter(UART):
    read_buffer = bytearray(100)
    command = None
    page = None
    id = None
    touch_event = None
    x = None
    y = None
    data = None
    def __init__(self, port=1,tx=4,rx=5, baud=9600):
#    def __init__(self, port=1, baud=9600):
        super(Nextion_Dieter, self).__init__(port, baud)
    def send(self, command, *args):
        length = len(args)
        for arg in args:
            length += len(str(arg))
        write_buffer = bytearray(len(command) + length + 3)
        write_buffer[0: len(command)] = bytes(command, 'ASCII')
        index = 0
        for arg in args:
            if index > 0:
                write_buffer[len(command) + index:len(command) + index + 1] = b','
                write_buffer[len(command) + index:len(command) + index + 1] = b' '
            #write_buffer[len(command) + index:len(command) + index + 1] = b' '
            write_buffer[len(command) + index + 1:len(command) + index + 1 + len(str(arg))] = bytes(str(arg), 'ASCII')
            index += 1 + len(str(arg))
        write_buffer[-3:] = b'\xff\xff\xff'
##        print(write_buffer)
        self.write(write_buffer)
    def check_data(self, callback):
        if self.any():
#            print(self.any())
            data = b''
            while not data.endswith(b'\xff\xff\xff'):
                data = b''.join((data, self.read(self.any())))
            self.read_buffer = data
#            print("erkannt------- ", self.read_buffer, "-----")
#            print(len (data))
            chars = (len (data))
#            print(self.read_buffer)
#            print(chars, "Zeichen")
            index = 0
            while index < (chars):
                self.command = self.read_buffer[index]
                index += 1
                if self.command in [R_COMMAND_TOUCH_EVENT, R_COMMAND_PAGE_ID]:
                    self.page = self.read_buffer[index]
                    index += 1
                if self.command == R_COMMAND_TOUCH_EVENT:
                    self.id = self.read_buffer[index]
                    index += 1
                if self.command in [R_COMMAND_TOUCH_COORDINATE, R_COMMAND_TOUCH_COORDINATE_SLEEP_MODE]:
                    self.x = self.read_buffer[index:index + 2]
                    self.y = self.read_buffer[index + 2:index + 4]
                    index += 4
                if self.command in [R_COMMAND_TOUCH_EVENT, R_COMMAND_TOUCH_COORDINATE, R_COMMAND_TOUCH_COORDINATE_SLEEP_MODE]:
                    self.touch_event = self.read_buffer[index]
                    index += 1
                if self.command == R_COMMAND_STRING_DATA:
                    length = 0
                    while self.read_buffer[index + length:index + length + 3] != b'\xff\xff\xff':
                        length += 1
                    self.data = self.read_buffer[index:index + length]
                    index += length
                    self.page = self.data
                if self.command == R_COMMAND_NUMERIC_DATA:
                    self.data = ustruct.unpack('<i', self.read_buffer[index:index + 4])[0]
                    index += 4
                    callback(command=self.command, page=self.page, id=self.id, touch_event=self.touch_event)
                    self.command = None
                    self.page = None
                    self.id = None
                    self.touch_event = None
                    self.x = None
                    self.y = None
                    self.data = None
                    return
                if self.read_buffer[index: index + 3] == b'\xff\xff\xff':
                    index += 3
                    # Reset
                    self.command = None
                    self.page = None
                    self.id = None
                    self.x = None
                    self.y = None
                    self.data = None
                    index = 0
                    self.command = None
                    self.page = None
                    self.id = None
                    self.x = None
                    self.y = None
                    self.data = None
                    print('ungültiger Befehl')
                    callback(command=self.command, page="ungültiger", id="Befehl", touch_event=self.touch_event)
                    return
My code:
import utime
import nextion_dieter
#oder UART0 (RX Nextion) auf GP0 (TX Nextion) auf GP1
n = nextion_dieter.Nextion_Dieter(1)
sensor_temp = machine.ADC(4)
conversion_factor = 3.3 / 65535
#wenn vom Nextion gesendet wird 1 sonst 0
sendung = 0
Volt = 200
Amper = 10000
egal='egal'
#RX-Pin durch Interrupt abfragen
gesendet = machine.Pin(5)
def int_handler(pin):
    gesendet.irq(handler=None)
    global sendung
#    print(sendung)
    sendung = 1
gesendet.irq(trigger=machine.Pin.IRQ_RISING, handler=int_handler)
#gesendet.irq(trigger=machine.Pin.IRQ_FALLING, handler=int_handler)#Pin.IRQ_RISING | Pin.IRQ_FALLING
#gesendet.irq(trigger=machine.Pin.IRQ_RISING | Pin.IRQ_FALLING, handler=int_handler)
n.send('page','Daten')#                    wechselt zur Seite Daten
# #n.send('Daten.t0.txt="9ab"')#            im Textfeld als Text einfügen
n.send('Daten.t0.txt="'+str(Volt)+'"')#   im Textfeld als Text einfügen
# #n.send('Daten.x0.val=1')#                im FloatFeld als formatierte Zahl einfügen
n.send('Daten.x0.val='+str(Amper)+'')#    im FloatFeld als formatierte Zahl einfügen
n.send('vis', 'b0', 1)#                  im Button b0 sichtbar 1 unsichtbar 0
#n.send('b0.txt="Button1"')#               Button beschriften
def nextion_callback(command, page, id, touch_event):
    #print('command: %s page: %s id: %s, touch_event: %s' % (command, page, id, touch_event))
    if (str(command)) == "101":
        komando = int(command)
        Seite = int(page)
        id_num = int(id)
        touch = int(touch_event)
        print("erkanntes Komando =", komando, "auf Seite =", Seite, "id. =", id_num, "touch Ereigniss =", touch)
    if (str(command)) == "113":
        Zahl = int(page)
        print("erkannte Zahl = ", Zahl)
    if (str(command)) == "112":
        Text = page.decode('utf-8')
        print("erkannte Text = ", Text)
    utime.sleep(1)
    reading = sensor_temp.read_u16() * conversion_factor
    temperature = round(27 - (reading - 0.706) / 0.001721, 2)
    print(temperature)
    n.send('Daten.t0.txt="'+str(temperature)+" grad"+'"')#   im Textfeld als Text einfügen
    n.check_data(nextion_callback)
    if sendung == 1:
#	n.check_data(nextion_callback)
	gesendet.irq(handler=int_handler)
        sendung = 0
So ist alles perfekt
    if sendung == 1:
        sendung = 0
So I have problems
    if sendung == 1:
        sendung = 0
The problem:
if I
# n.check_data (nextion_callback)
Execute before the If condition everything is great.
It is no longer going well in the IF condition executed,
not every command is recognized.
In both cases the interrupt is executed.
Even pauses before and after the call do not change anything.
Dieter.Tepe@live.de
Re: Problem with the interrupt
Post by Dieter.Tepe@live.de » Sat Apr 10, 2021 12:22 pm
So it works fine now.
    if sendung == 1:
by calling the callback 2 times in a row.
But I don't know why that is now.
I would be grateful for an explanation.
