Driver for ST7735 (blue tab)
Posted: Tue Jun 01, 2021 6:47 am
by fdufnews
Just made some modification on a driver from @pythoncoder to use the blue tab variation of a 80 x 160 display using ST7735 driver chip. The driver is here in the drivers directory.
The differences with the original driver are :
  • an offset on one axis
  • inverted colors
I have added parameters in the constructor in order to manage more than one display, examples are here.
One of the example is a faux nixie clock on which the numbers shape can be changed with a rotary encoder.
Re: Driver for ST7735 (blue tab)
Posted: Tue Jun 01, 2021 8:48 am
Good work. The multiple variants of the ST7735 are confusing. I chose to support Adafruit displays because I trust them not to suddenly change to a different variant...
Your driver should work with nano-gui should you feel inclined to try it.
I love your simulated Nixie tube font!
Posted: Tue Jun 01, 2021 1:01 pm
by fdufnews
Thank you.
When I adapt a driver, I try to keep the interface as much as possible to assure compatibility with the original one.
