im trying to se up date/time on real time clock DS1302. I have defined rtc module and i have the right library installed. I just need to find out how to set date and time in the beginning. I tried to define each parameter separately and also all of them at once but the result is still the same. It just keep printing 0 in every category. So, is there any command that i need to use before setting up the RTC?
Here are variants code im using:
first one, each parameter separately:
import DS1302
from time import sleep
ds = DS1302.DS1302(clk=Pin(0), dio=Pin(1), cs=Pin(2))
ds.start()
ds.year(2021)
ds.month(12)
ds.day(15)
ds.weekday(3)
ds.hour(15)
ds.second(7)
ds.minute(3)
#ds.date_time([2021, 1, 8, 3, 24, 5, 6])
print(ds.date_time())
sleep(1)
import DS1302
ds.start()
#ds.year(2021)
#ds.month(12)
#ds.day(15)
#ds.weekday(3)
#ds.hour(15)
#ds.second(7)
#ds.minute(3)
sleep(1)
DS1302_REG_SECOND = (0x80)
DS1302_REG_MINUTE = (0x82)
DS1302_REG_HOUR = (0x84)
DS1302_REG_DAY = (0x86)
DS1302_REG_MONTH = (0x88)
DS1302_REG_WEEKDAY= (0x8A)
DS1302_REG_YEAR = (0x8C)
DS1302_REG_WP = (0x8E)
DS1302_REG_CTRL = (0x90)
DS1302_REG_RAM = (0xC0)
class DS1302:
def __init__(self, clk, dio, cs):
self.clk = clk
self.dio = dio
self.cs = cs
self.clk.init(Pin.OUT)
self.cs.init(Pin.OUT)
def _dec2hex(self, dat):
return (dat//10) * 16 + (dat % 10)
def _hex2dec(self, dat):
return (dat//16) * 10 + (dat % 16)
def _write_byte(self, dat):
self.dio.init(Pin.OUT)
for i in range(8):
self.dio.value((dat >> i) & 1)
self.clk.value(1)
self.clk.value(0)
def _read_byte(self):
d = 0
self.dio.init(Pin.IN)
for i in range(8):
d = d | (self.dio.value() << i)
self.clk.value(1)
self.clk.value(0)
return d
def _get_reg(self, reg):
self.cs.value(1)
self._write_byte(reg)
t = self._read_byte()
self.cs.value(0)
return t
def _set_reg(self, reg, dat):
self.cs.value(1)
self._write_byte(dat)
self.cs.value(0)
def _wr(self, reg, dat):
self._set_reg(DS1302_REG_WP, 0)
self._set_reg(reg, dat)
self._set_reg(DS1302_REG_WP, 0x80)
def start(self):
t = self._get_reg(DS1302_REG_SECOND + 1)
self._wr(DS1302_REG_SECOND, t & 0x7f)
def stop(self):
self._wr(DS1302_REG_SECOND, t | 0x80)
def second(self, second=None):
if second == None:
return self._hex2dec(self._get_reg(DS1302_REG_SECOND+1)) % 60
self._wr(DS1302_REG_SECOND, self._dec2hex(second % 60))
def minute(self, minute=None):
if minute == None:
return self._hex2dec(self._get_reg(DS1302_REG_MINUTE+1))
self._wr(DS1302_REG_MINUTE, self._dec2hex(minute % 60))
def hour(self, hour=None):
if hour == None:
return self._hex2dec(self._get_reg(DS1302_REG_HOUR+1))
self._wr(DS1302_REG_HOUR, self._dec2hex(hour % 24))
def weekday(self, weekday=None):
if weekday == None:
return self._hex2dec(self._get_reg(DS1302_REG_WEEKDAY+1))
self._wr(DS1302_REG_WEEKDAY, self._dec2hex(weekday % 8))
def day(self, day=None):
if day == None:
return self._hex2dec(self._get_reg(DS1302_REG_DAY+1))
self._wr(DS1302_REG_DAY, self._dec2hex(day % 32))
def month(self, month=None):
if month == None:
return self._hex2dec(self._get_reg(DS1302_REG_MONTH+1))
self._wr(DS1302_REG_MONTH, self._dec2hex(month % 13))
def year(self, year=None):
if year == None:
return self._hex2dec(self._get_reg(DS1302_REG_YEAR+1)) + 2000
self._wr(DS1302_REG_YEAR, self._dec2hex(year % 100))
def date_time(self, dat=None):
if dat == None:
return [self.year(), self.month(), self.day(), self.weekday(), self.hour(), self.minute(), self.second()]
self.year(dat[0])
self.month(dat[1])
self.day(dat[2])
self.weekday(dat[3])
self.hour(dat[4])
self.minute(dat[5])
self.second(dat[6])
def ram(self, reg, dat=None):
if dat == None:
return self._get_reg(DS1302_REG_RAM + 1 + (reg % 31)*2)
self._wr(DS1302_REG_RAM + (reg % 31)*2, dat)
