Bosch BME280 driver
Re: Bosch BME280 driver
Post by pythoncoder » Fri Jul 22, 2016 10:23 am
When you unzip it you should see a directory xtensa-lx106-elf - ensure your PATH points to it and you should be good to go, simply by moving to micropython/esp8266 in your clone of the source and following the build instructions. There is no installation required.
The only 'gotcha' I encountered is that the directory 'xtensa-lx106-elf' itself contains a subdirectory 'xtensa-lx106-elf'. Ensure that it looks like this when you unzip it.
[adminpete@axolotl]: /mnt/qnap2/data/Projects/MicroPython
$ cd xtensa-lx106-elf
[adminpete@axolotl]: /mnt/qnap2/data/Projects/MicroPython/xtensa-lx106-elf
$ pwd
$ ls -l
total 736
drwx------ 2 adminpete adminpete   4096 Jul 19 13:29 bin
-rw------- 1 adminpete adminpete 725887 Jul 10 18:49 build.log.bz2
drwx------ 3 adminpete adminpete   4096 Jul 19 13:30 include
drwx------ 4 adminpete adminpete   4096 Jul 19 13:30 lib
drwx------ 3 adminpete adminpete   4096 Jul 19 13:29 libexec
drwx------ 4 adminpete adminpete   4096 Jul 19 13:30 share
drwx------ 6 adminpete adminpete   4096 Jul 19 13:30 xtensa-lx106-elf
$ echo $PATH
/mnt/qnap2/Scripts:/mnt/qnap2/data/Projects/MicroPython/xtensa-lx106-elf/bin:/home/adminpete/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games
warren
Post by warren » Fri Jul 22, 2016 1:58 pm
pythoncoder wrote:When you unzip it you should see a directory xtensa-lx106-elf - ensure your PATH points to it and you should be good to go, simply by moving to micropython/esp8266 in your clone of the source and following the build instructions. There is no installation required.
Success!! Thank you so much.
And one further question:
In the ESP8266 folder are two folders: "modules" and "scripts"
Where is the documentation about these two folders and the difference between them?
Thanks again - much appreciated...
Post by pythoncoder » Fri Jul 22, 2016 4:11 pm
warren wrote:...In the ESP8266 folder are two folders: "modules" and "scripts"
The modules directory is for modules to be frozen as bytecode. I wish I knew the purpose of the scripts directory. Frozen bytecode is a very recent feature for ESP8266 and I'm not aware of any official documentation.
Post by dhylands » Fri Jul 22, 2016 4:18 pm
If my reading of the makefile is correct, scripts should just contain python source that you want frozen (but not precompiled), whereas modules will contain scripts which get precompiled into bytecode.
warren
Post by warren » Fri Jul 22, 2016 4:59 pm
OK thank you - this has been very helpful.
angel
Post by angel » Sun Aug 14, 2016 8:03 am
Hello Jim,
You mention you know what changes to do to get more accurate readings?
I have connected the WiPy to the sensor but the readings are off.
Thank you!
Angel
jiemde
Post by jiemde » Tue Sep 27, 2016 6:24 pm
Hi all, I'm trying to read an BME280 module first with an "Amica" nodemcu with only 4 Mbits of flash memory without success, and now with an version 3 with 32Mbits of Flash memory, but after transfering the bme280 library, when I try to execute the main.py with:
import bme280
i2c = machine.I2C(scl=machine.Pin(5), sda=machine.Pin(4))
bme = bme280.BME280(i2c=i2c)
print(bme.values)
I will obtain an error message that there is no "BME280" in the module "bme280"
When, in esplorer, I do
 import bme280
>>> dir(bme280)
['__name__']
Effectively there is no "BME280" in the list !
If someone have an idea where I go wrong, thanks in adavnce for solution.
Best regards
Jiemde
jiemde
Post by jiemde » Tue Nov 08, 2016 2:05 pm
pythoncoder wrote:Assuming you've double checked that bme280.py on the ESP8266 is correct, I suspect you have run out of RAM. Are you running it from webrepl? It might be worth not running webrepl and using a direct connection. Executing the following after the error may be informative:
import micropython
micropython.mem_info()
Hi All, don't really understand why I don't receive any answer to the same problem with an ESP8266 with 4Mbyte !
Best regards
Jiemde
kfricke
Post by kfricke » Tue Nov 08, 2016 4:14 pm
The problem is not the size of the flash (ROM). It is based on the limits of heap (RAM). What firmware build number/version are you using?
The BME280 driver is quite a memory hog (uses attributes instead of the suggested functions to access the sensor values, but is kindly developed with absence of floating point support in mind!), but I do use this together with my HDC1008 driver and quite large "user space code" modules loaded from flash filesystem. They do implement my sensor network nodes. Only uMQTT (robust and simple) is baked as frozen bytecode into my firmware image.
upymar
Post by upymar » Sat Feb 04, 2017 8:10 am
[quote="catdog2"]I have modified the driver quite a bit for the ESP8266:
https://github.com/catdog2/mpy_bme280_esp8266
The main goal was to make It less memory hungry, especially during import. Worked I think. I only tested it with a BMP280 as I don't possess a BME280 yet.[/quote]
I use NodeMCU with esp8266-20170108-v1.8.7.bin and BME280
I always have to call twice
[code]import bme280[/code]
as I get this error after the first call:
[code]Traceback (most recent call last):
File "bme280.py", line 5[/code]
After
[code]bme = bme280.BME280(i2c=i2c)[/code]
I get:
AttributeError: 'module' object has no attribute 'BME280'[/code]
Also, I am unsure about the pin numbers in
[code]i2c = machine.I2C(scl=machine.Pin(5), sda=machine.Pin(4))[/code]
Could you please help me?
