I2C LCD Library... Help!
raspi3ua
Re: I2C LCD Library... Help!
Post by raspi3ua » Sat Mar 18, 2017 5:03 pm
I have the same problem.
My hardware:
-16x2 HD44780 Character LCD with IIC/I2C Serial Interface Adapter Module
-NodeMcu ESP8266 V3 (with the latest micropython firmware)
I can scan LCD on I2C.
>>> from machine import Pin, I2C
>>> i2c = I2C(scl=Pin(5), sda=Pin(4), freq=100000)
>>> i2c.scan()
[63]
Is there any way to write "Hello World" to LCD using I2C from NodeMCU?
Thanks.
I can't find I2C support for NodeMCU on https://github.com/dhylands/python_lcd
Post by dhylands » Sat Mar 18, 2017 5:12 pm
I guess we need to establish which i2c backpack you're using (there are quite a few).
None of the ones I've used have an address of 63?
If you disconnect the LCD and repeat the scan does 63 still show up?
sequel
Post by sequel » Sat Mar 18, 2017 6:33 pm
raspi3ua, did you try the code (esp8266_i2c_lcd.py and lcd.py) that i have posted on this thread on Sat Oct 01, 2016 2:36 am?
NodeMCU is basically an esp8266 board so the code shall work.
When using the two files mentioned above, you could try something like this (adjust the pins to your setup) :
from esp8266_i2c_lcd import I2cLcd
lcd = I2cLcd(i2c, 0x63, 2, 16)
lcd.clear()
lcd.putstr('Hello World!')
But like dhylands said, 0x63 seems odd for an I2C LCD backpack address.
Post by dhylands » Sat Mar 18, 2017 6:38 pm
Note that i2c.scan reports addresses in decimal so 63 = 0x3F not 0x63
sequel
Post by sequel » Sat Mar 18, 2017 6:45 pm
Oh yeah! i've missed that one :)
raspi3ua
Post by raspi3ua » Sat Mar 18, 2017 7:55 pm
[quote="dhylands"] I guess we need to establish which i2c backpack you're using (there are quite a few).
If you disconnect the LCD and repeat the scan does 63 still show up? [/quote]
My hardware is from Aliexpress :-) This one:
https://www.aliexpress.com/item/1602-16 ... 0.0.CZ7EC3
https://www.aliexpress.com/item/V3-4M-b ... 0.0.CZ7EC3
I disconnect LCD and scan. Same number 63
>>> i2c.scan()
[63]
raspi3ua
Post by raspi3ua » Sat Mar 18, 2017 8:05 pm
I can read numbers on I2C Backpack chip: "PCF8574AT L21521"
I think this one https://www.nxp.com/documents/data_sheet/PCF8574.pdf
raspi3ua
Post by raspi3ua » Sat Mar 18, 2017 8:39 pm
sequel wrote:raspi3ua, did you try the code (esp8266_i2c_lcd.py and lcd.py) that i have posted on this thread on Sat Oct 01, 2016 2:36 am?
Connect NodeMCU ->I2C Backpack ->LCD
All LCD is white.
>>> lcd = I2cLcd(i2c, 63, 2, 16) <--- Just LCD blink
>>> lcd.clear() <--- nothing
>>> lcd.putstr('Hello World!') <--- nothing
>>> i2c.scan()
[63]
File "esp8266_i2c_lcd.py", line 26, in __init__
OSError: [Errno 19] ENODEV
>>> lcd = I2cLcd(i2c, 0x3F, 2, 16) <--- Just LCD blink
>>> i2c.writeto(63, '1') <--- All LCD is black now
1
>>> i2c.writeto(63, '8') <--- All LCD is while now
1
Post by dhylands » Sat Mar 18, 2017 8:51 pm
raspi3ua wrote:
dhylands wrote: I guess we need to establish which i2c backpack you're using (there are quite a few).
>>> i2c.scan()
[63]
That tells me that your device isn't being seen by the scan then. Check to make sure you haven't swapped SDA and SCL. Also make sure that vcc and ground are hooked up.
The PCF8574 has an I2C address of 0x20 thru 0x27 (32 thru 39). Device 63 is something else on the i2c bus and not your LCD backpack.
raspi3ua
Post by raspi3ua » Sat Mar 18, 2017 9:15 pm
dhylands wrote:That tells me that your device isn't being seen by the scan then. Check to make sure you haven't swapped SDA and SCL. Also make sure that vcc and ground are hooked up.
Very strange. Tried to swap SDA and SCL, tried to change cables, tried to disconnect any cable - always results []
>>> i2c.scan()
>>> i2c.scan()
>>> i2c.scan()
>>> i2c.scan()
>>> i2c.scan()
[63]
>>> i2c.scan()
>>> i2c.scan()
>>> i2c.scan()
I have 63 when pins connected like this:
https://www.losant.com/hs-fs/hubfs/Blog ... wiring.jpg
