IS31fl3731 Charlie-Plexed LED Matrix
Post by deshipu » Sat Jul 09, 2016 12:41 pm
This chip is pretty nice. It's used in Adafruit's 16x9 LED matrix and in their CharlieWing for the Feather. You get a monochromatic matrix of up to 144 LEDs, with hardware PWM and blinking. It also has 8 frames of memory, and can fade between them, or play animations with them -- optionally synchronized to music! The code is at https://bitbucket.org/thesheep/micropyt ... 1fl3731.py
I looked at the datasheet, saw all the nice extra features the chip has, and decided to implement them all in this library -- the Adafruit library basically only lets you set the pixels.
marfis
Re: IS31fl3731 Charlie-Plexed LED Matrix
Post by marfis » Sat Jul 09, 2016 5:46 pm
great, thanks for that. Will be on my list for a next adafruit order :)
Post by deshipu » Sat Jul 09, 2016 5:56 pm
Let me know how it works for you. I only tested it with the CharlieWing, but it should work the same with the other matrix. The CharlieWing seems to lack the audio input pin, though :-(
marfis
Post by marfis » Sat Jul 09, 2016 7:10 pm
https://www.adafruit.com/products/2946
seems to have an audio input, however no on board LEDs (they can be added via https://www.adafruit.com/products/2948 though which gives you the full 144 LED configuration).
MCHobby
Post by MCHobby » Sat Jun 27, 2020 1:16 pm
I made a backport to MicroPython based board.
Code is available here https://github.com/mchobby/esp8266-upy/ ... ter/is31fl
IHOXOHI
Post by IHOXOHI » Tue Sep 08, 2020 9:15 am
I would like to use the matrix for display time.
Logically, on the 15x7 charlieWing matrice, there is a way for display 4 numbers of 3 pixels in width direction and 3 spaces between numbers.
Currently size of number is too big for doing that.
So, I need to change the "font" using by frambuffer.
In the doc, I have found this information:
"All characters have dimensions of 8x8 pixels and there is currently no way to change the font"
Currently means that it could be possible to change it?
If somoene has an advise for doing that...
Thanks.
IHOXOHI
Post by IHOXOHI » Fri Sep 11, 2020 7:45 pm
Yap,
A script for display time on charlieWing matrix, from a newbie, so very heavy for nothing I think, ..., but it works.
Enjoy!
from machine import I2C
import is31fl3731 as is31f
i2c1 = I2C(scl='X9', sda='X10', freq=100000)
display = is31f.CharlieWing(i2c1)
#chiffre 0 sur la deuxieme place
def Chiffre_0(a):
        display.pixel(5+a,1,5)
        display.pixel(4+a,2,5)
        display.pixel(6+a,2,5)
        display.pixel(4+a,3,5)
        display.pixel(6+a,3,5)
        display.pixel(4+a,4,5)
        display.pixel(6+a,4,5)
        display.pixel(5+a,5,5)
#chiffre 1 sur la deuxieme place
def Chiffre_1(a):
        display.pixel(5+a,2,5)
        display.pixel(5+a,3,5)
        display.pixel(5+a,4,5)
def Chiffre_2(a):
        display.pixel(4+a,5,5)
        display.pixel(6+a,5,5)
def Chiffre_3(a):
        display.pixel(4+a,1,5)
def Chiffre_4(a):
def Chiffre_5(a):
        display.pixel(6+a,1,5)
def Chiffre_6(a):
def Chiffre_7(a):
def Chiffre_8(a):
def Chiffre_9(a):
global b
b = 2
def point(b):
    if b % 2 == 0:
        display.pixel(7,6,5)
global phrase1, phrase2, phrase3, phrase4
phrase1, phrase2, phrase3, phrase4 = "", "", "", ""
    heure = time.localtime()
    ###break down time
    heure1 = str(heure[3])
    heure11 = int(heure1[0])
        heure12 = int(heure1[1])
    except:
        heure11 = 0
        heure12 = int(heure1[0])
    heure2 = str(heure[4])
    heure21 = int(heure2[0])
        heure22 = int(heure2[1])
    except:
        heure21 = 0
        heure22 = int(heure2[0])
    ###link time to display commands
    for x in range(3):
        if heure11 == x:
            global phrase1
            phrase1 = "Chiffre_" + str(x) + "(" + str(-4) + ")"
    for x in range(10):
        if heure12 == x:
            global phrase2
            phrase2 = "Chiffre_" + str(x) + "(" + str(0) + ")"
    for x in range(6):
        if heure21 == x:
            global phrase3
            phrase3 = "Chiffre_" + str(x) + "(" + str(4) + ")"
    for x in range(10):
        if heure22 == x:
            global phrase4
            phrase4 = "Chiffre_" + str(x) + "(" + str(8) + ")"
    ###display command
    def affichage():
         convert1 = eval(phrase1)
         convert2 = eval(phrase2)
         convert3 = eval(phrase3)
         convert4 = eval(phrase4)
         return convert1
         return convert2
         return convert3
         return convert4
    affichage()
    b += 1
    point(b)
    time.sleep(1)
    display.fill(0)
mcauser
Post by mcauser » Wed Sep 16, 2020 12:13 pm
Hey @deshipu
Your link is now 404ing: https://bitbucket.org/thesheep/micropyt ... 1fl3731.py
Are you migrating away from bitbucket?
Post by deshipu » Wed Sep 16, 2020 11:09 pm
I'm not migrating. Bitbucket decided to permanently delete all Mercurial repositories a while ago.
