Porting Nokia5110 lcd code in C to available in upython?
Delebel
Post by Delebel » Fri May 26, 2017 9:33 pm
Hi I'm very certainly a Newbie but hopefully a persistent one so that I will advance my project... So turning C code from an 8 bit (pic18f4620) platform to some kind of driver like for the LCD upython already supports. Specially the LCD is a Nokia3110/5110 type. I got the code off github originally. I just want to get some guidance as to what an where to look for info on doing it because I wish to learn in the process.
Thanks Denis the newbie...
Re: Porting Nokia5110 lcd code in C to available in upython?
Post by Roberthh » Sat May 27, 2017 7:16 am
If you search thi forum for 5110 you'll find a driver and a lot of useful discussion too. Just use the "search" button. @mcauser has contributed many useful drivers.
mcauser
Post by mcauser » Thu Jun 01, 2017 5:29 am
I've used mbirth's wipy-upcd8544 driver in a bunch of my ESP8266 projects.
https://github.com/mbirth/wipy-upcd8544
It was originally created for wipy, but with a few small modifications, works with ESP8266.
https://github.com/mbirth/wipy-upcd8544/issues/1
Edit: since have created my own version, which is compatible with MicroPython 1.9, ESP8266 and uses the framebuf:
https://github.com/mcauser/micropython-pcd8544
https://github.com/mcauser/MicroPython- ... Nokia-5110
https://github.com/mcauser/MicroPython- ... me-of-Life
https://github.com/mcauser/MicroPython- ... 10-Bitcoin
It's really easy to write to the display. You can either throw a 84x48 byte array (84*48/8=504 bytes) at the lcd.data() method, or use framebuf, which lets you draw basic shapes an use fonts.
Bytes in the byte array passed to data() are in column major / horizontal orientation.
eg.
from upcd8544 import PCD8544
spi = SPI(1)
spi.init(baudrate=8000000, polarity=0, phase=0)
RST = Pin(0, Pin.OUT)
CE = Pin(2, Pin.OUT)
DC = Pin(15, Pin.OUT)
BL = Pin(12, Pin.OUT)
lcd = PCD8544(spi, RST, CE, DC, BL)
from framebuf import FrameBuffer1
width = 84
height = 48
buffer = bytearray((height // 8) * width)
framebuf = FrameBuffer1(buffer, width, height)
# black screen
framebuf.fill(1)
lcd.data(buffer)
# white screen
framebuf.fill(0)
lcd.data(buffer)
# write some text
framebuf.text('Hello',0,0)
lcd.data(buffer)
# reset
lcd.clear()
# draw a 84x48 picture
image = bytearray([
0x80,0x00,0x00,0x80,0x00,0x00,0x80,0x00,0x00,0x80,0x00,0x00,0x80,0x00,0x00,0x80,0x00,0x00,0x80,0x80,0x40,0x40,0x40,0x80,0x80,0xC0,0xC0,0x40,0xC0,0xA0,0xE0,0xC0,0xE0,0xE0,0xF0,0xF0,0xF8,0xF8,0xF8,0xFC,0xFC,0xFE,0xEE,0xF4,0xF0,0xF0,0x70,0x30,0x00,0x80,0x00,0x00,0x80,0x00,0x0C,0x9C,0x1C,0x38,0xB8,0x38,0x38,0xB8,0xF8,0xF0,0xF0,0xF0,0xF0,0xF0,0xF0,0xF0,0xF0,0xF0,0xF0,0xF0,0xF0,0xF0,0xF0,0xF0,0xF0,0xF0,0xF8,0xF8,0xF8,0xF8,
0x88,0x20,0x8A,0x20,0x08,0x22,0x08,0x00,0x0A,0x00,0x00,0x02,0x80,0x71,0xBA,0xDA,0xFD,0xDD,0xED,0xDE,0xEE,0xF7,0xFF,0xFB,0xFD,0xFD,0xFE,0xFF,0x7F,0x3F,0x1F,0x9F,0x3F,0x7F,0x6F,0x0F,0xAF,0x1F,0xBF,0x3E,0x3C,0x7A,0x78,0x70,0x22,0x88,0xA0,0x2A,0x80,0x08,0x62,0xE0,0xE0,0xF2,0xF0,0x58,0xDA,0xF8,0xFC,0x92,0xFE,0xFF,0xFF,0xD3,0xFF,0xFD,0xF3,0xE1,0xF0,0xF9,0x7F,0xBF,0x3F,0x8F,0x2F,0x4F,0xAF,0x0F,0x4F,0xA7,0x0F,0xAF,0x87,0x2F,
0x82,0x80,0x20,0xC0,0x80,0x80,0x50,0x40,0xC4,0xD0,0xA0,0xE8,0xE4,0xEA,0xFF,0xFB,0xFD,0xFF,0xFF,0xFF,0xFF,0xFF,0xEF,0x4F,0x27,0x53,0xA8,0x54,0x29,0x4A,0xB5,0x82,0xAC,0xA1,0x8A,0xB6,0x50,0x4D,0x32,0xA4,0x4A,0xB4,0xA9,0x4A,0x52,0xB4,0xAA,0x45,0xA8,0xDA,0x22,0xAC,0xD2,0x2A,0x52,0xA8,0x52,0x4C,0xB0,0xAD,0x43,0x5B,0xB3,0x45,0xA8,0x5B,0xA3,0xAB,0x55,0xA8,0x52,0x54,0xA9,0x56,0xA8,0x45,0xBA,0xA4,0x49,0x5A,0xA2,0x54,0xAA,0x52,
0xFE,0xFF,0xFF,0xFE,0xFD,0xFF,0xFF,0xFF,0xFE,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x7F,0xFF,0xFE,0xBF,0x7F,0xBF,0xBF,0xFF,0xDF,0xBF,0x5F,0xDF,0x7F,0xDF,0x7F,0xDF,0xAF,0x7F,0xEE,0x8E,0xF1,0x6E,0x99,0xF7,0x6A,0xDD,0xB2,0x6E,0xD5,0x7A,0xD7,0xAC,0x75,0xDB,0x6D,0xD5,0x7A,0xD7,0xAC,0x7B,0xE5,0xDE,0xA9,0x77,0xDA,0xB5,0xEE,0x59,0xB6,0xEB,0xDD,0xB6,0x69,0xD6,0xBF,0xE8,0x55,0xEF,0xB9,0xD6,0xED,0xB5,0x5B,
0xAB,0xFF,0xFD,0xF7,0xFF,0x01,0x01,0x01,0x01,0xE1,0xC1,0x81,0x03,0x05,0x0F,0x1D,0x2F,0x7E,0x01,0x00,0x01,0x01,0xFF,0xFE,0x03,0x01,0x01,0x00,0xF1,0xF0,0xF1,0x71,0xF1,0xF1,0xB1,0xF1,0x01,0x01,0x01,0x03,0xFE,0xFF,0x01,0x01,0x01,0x01,0xBE,0x1B,0x0D,0x07,0x03,0x41,0xE1,0xF1,0xF9,0x6D,0xFF,0xFF,0x00,0x01,0x01,0x01,0xFF,0xFF,0xEB,0x3E,0x0D,0x03,0x01,0x41,0x71,0x70,0x41,0x01,0x03,0x0E,0x3B,0xEF,0xFE,0xFB,0xEE,0x7D,0xF7,0xFF,
0xFF,0xFF,0xFF,0xFE,0xFF,0xF0,0xF0,0xF0,0xF0,0xFF,0xFF,0xFF,0xFF,0xFE,0xFC,0xF8,0xF0,0xF0,0xF0,0xF0,0xF0,0xF0,0xFF,0xFF,0xF8,0xF0,0xF0,0xF0,0xF1,0xF1,0xF1,0xF1,0xF1,0xF1,0xF1,0xF1,0xF0,0xF0,0xF0,0xF8,0xFF,0xFF,0xF0,0xF0,0xF0,0xF0,0xFF,0xFF,0xFE,0xFC,0xF8,0xF0,0xF0,0xF1,0xF3,0xF7,0xFF,0xFF,0xF0,0xF0,0xF0,0xF0,0xFF,0xF3,0xF0,0xF0,0xF0,0xFC,0xFC,0xFC,0xFC,0xFC,0xFC,0xFC,0xFC,0xF0,0xF0,0xF0,0xF3,0xFF,0xFF,0xFF,0xFF,0xFF
lcd.data(image)
This is the bitmap displayed above:
https://github.com/mcauser/WeMos-D1-min ... -84x48.bmp
The Nokia loading screen.
Delebel
Post by Delebel » Thu Jun 01, 2017 12:25 pm
Thanks I'm still wrestling with the learning curve to learn uPython as an the old school C coder. I've setup the Pyboard with a compatible connector to my Homestat (thermostat/venmar/humidifyer/dehumidifyer+AC) IO panel so that I can experiment with the Pyboard and then retreat to my old C controller so I don't freeze at night... LOL
Thanks again...Denis
Delebel
Post by Delebel » Wed Jul 25, 2018 4:02 pm
Finally got the Nokia LCD to work with the example. Had a hardware issue with the io lines (SPI In/Out lines reversed). I also was trying to get the LCD to work without a RST line because I was getting away with it on my C coded platform. When I added it back the example code used it, it worked immediately. I will try later to have the LCD reset to happen in hardware (power up RC). Thanks for the feedback...Denis
