convert ds18b20 serial number
Posted: Sat Aug 12, 2017 8:04 pm
by c.man
I'm running a code for temperature acquisition (with digital sensor ds18b20)
import onewire, ds18x20
# the device is on GPIO12
dat = machine.Pin(12)
# create the onewire object
ds = ds18x20.DS18X20(onewire.OneWire(dat))
# scan for devices on the bus
print('found devices:', roms)
# loop 10 times and print all temperatures
for i in range(10):
    print('temperatures:', end=' ')
        print(ds.read_temp(rom), end=' ')
    print()
in output I have:
found devices: [bytearray(b'(\xb4\x95f\x05\x00\x00\x0c')]
temperatures: 27.25
temperatures: 27.25
temperatures: 27.25
temperatures: 27.25
temperatures: 27.25
temperatures: 27.25
temperatures: 27.25
temperatures: 27.25
temperatures: 27.25
temperatures: 27.25
I want to convert devices from bytearray in string (in ubuntu/raspberry I have "28-0000056695b4").
How I to do ?
Re: convert ds18b20 serial number
Posted: Sat Aug 12, 2017 11:19 pm
by deshipu
>>> hex(int.from_bytes(b'(\xb4\x95f\x05\x00\x00\x0c', 'little'))
'0xc0000056695b428'
Posted: Sun Aug 13, 2017 6:09 am
by c.man
thanks !
Posted: Sat Mar 03, 2018 9:54 am
by ajocius
How to add this to the code? Testing this sensor as well.
print('found devices:', hex(int.from_bytes(b'(roms', 'little'))))
does not work
Posted: Fri May 17, 2019 9:00 am
by navy
does not work
roms is an array so you should use it like this:
#serialnum = hex(int.from_bytes(roms[0], 'little'))
#print('serial:', serialnum)
or in example loop:
for i in range(5):
        serialnum = hex(int.from_bytes(rom, 'little'))
        print('sensor #', serialnum)
    print()
Posted: Fri May 17, 2019 6:37 pm
by kevinkk525
Always funny when someone revives a thread that is a year old :D
The solution of converting a rom to string is quite simple: ''.join('%02X' % i for i in iter(rom))
