Which Servo's
Posted: Mon Sep 25, 2017 4:07 pm
by roland_vs
Micropython supports the control of servo's.
Are there any particular type/brand of servo's that work well with the py-board?
Regards,
Roland
Re: Which Servo's
Posted: Mon Sep 25, 2017 5:19 pm
by dhylands
All RC style hobby servos should work. They all nominally expect a pulse of 1-2 msec sent approx 50-60Hz.
There are some high end digital servos that might not work.
And of course, the servo module wasn't designed to control servos like the ones used in CNC machines (low-end machines typically use steppers and higher end machines use servos).
Re: Which Servo's
Posted: Thu Oct 12, 2017 12:42 am
by trazee11
To complement the previous answer, if you aren't sure what specific type you should get, you can have companies that do customization regarding servos (this one for example:
http://www.powerjackmotion.com/product- ... tor-range/) to meet your requirements.
Re: Which Servo's
Posted: Thu Oct 12, 2017 1:49 am
by dhylands
trazee11 wrote:To complement the previous answer, if you aren't sure what specific type you should get, you can have companies that do customization regarding servos (this one for example:
Those are the types of Servos that are typically used in CNC machines, which are significantly different from the RC style servos that the MicroPython Servo module supports.
Re: Which Servo's
Posted: Thu Oct 12, 2017 4:52 am
by trazee11
[quote="dhylands"][quote="trazee11"]To complement the previous answer, if you aren't sure what specific type you should get, you can have companies that do customization regarding servos (this one for example:
http://www.powerjackmotion.com/product- ... tor-range/) to meet your requirements.[/quote]
Those are the types of Servos that are typically used in CNC machines, which are significantly different from the RC style servos that the MicroPython Servo module supports.[/quote]
Thanks for that, I just thought their custom-made OEM products can help. Anyway, I reviewed the sight and saw the servos' standard applications are for CNC, industrial applications, and etc.
Re: Which Servo's
Posted: Thu Oct 12, 2017 5:44 am
by mcauser
I've used two entry level TowerPro servos, SG90 and MG995.
They are not the fastest, strongest or most accurate, but they are easy to find and quite cheap.
You can find a SG90 for around $1 each. Very small and with plastic gears.
https://www.aliexpress.com/item/Free-Sh ... 64605.html
https://servodatabase.com/servo/towerpro/sg90
The MG995 servos are around $4 each. Bigger and with metal gears.
https://www.aliexpress.com/item/Free-sh ... 08918.html
https://servodatabase.com/servo/towerpro/mg995
If you are driving a lot of servos, an I2C PCA9685 module will save you some pins and give you an external power source to drive them.
https://www.aliexpress.com/item/16-Chan ... 55850.html
https://www.adafruit.com/product/815
