TinyRTC I2C Module DS1307 + AT24C32N
Online
mcauser
Post by mcauser » Wed Mar 28, 2018 12:22 pm
I created a driver for the TinyRTC I2C module. Features a DS1307 RTC IC + AT24C32N 32K EEPROM and headers for optional DS18B20.
https://github.com/mcauser/micropython-tinyrtc-i2c
It was only after I finished that I realised my STM32F407VET6 Mini actually has built-in hardware RTC and all I needed to do was attach a coin cell between GND + VBAT. :shock: Ah well, at least I learned all about RTCs and EEPROMs. You might find this driver useful for boards without a built-in RTC.
Blechi
Re: TinyRTC I2C Module DS1307 + AT24C32N
Post by Blechi » Fri Apr 27, 2018 9:12 pm
thank you for the drivers.
DS1307 works like a charm.
The AT24C32N however doesn't do what it's supposed to do:
On my TTGO ESP32 boards (latest loboris port)
when i enter this:
i2c = machine.I2C(scl=machine.Pin(22), sda=machine.Pin(21))
print('i2c scan:',i2c.scan())
import at24c32n
eeprom = at24c32n.AT24C32N(i2c)
# read 32 bytes starting from memory address 0
eeprom.read(0, 32)
i get this:
i2c scan: [80, 104, 118]
  File "<stdin>", line 7, in <module>
  File "at24c32n.py", line 42, in read
TypeError: extra keyword arguments given
I'm fairly new to Python, so i don't know what to look for.
Maybe someone wiser than me can chime in and show what i'm doing wrong here.
Thank you very much in advance.
Blechi
Post by pythoncoder » Sat Apr 28, 2018 10:12 am
Looking at the GitHub code for the AT24C32N driver the line number in your traceback looks wrong. I strongly suspect you have not got the latest version of the driver. I suggest you update and try again.
Blechi
Post by Blechi » Sun Apr 29, 2018 1:40 pm
Thank you for the reply.
Notepad++ had eaten the 4 empty lines in the license terms.
After having fixed that by downloading the latest version from
the result is:
  File "at24c32n.py", line 46, in read
when running this:
import at24c32n
eeprom.read(0, 32)
Online
mcauser
Post by mcauser » Tue May 01, 2018 11:06 am
Does the loboris port support readfrom_mem() with addrsize=16?
Blechi
Post by Blechi » Tue May 01, 2018 8:00 pm
That was the right hint.
In the Loboris port the read and write functions require adrlen = 2 instead of addrsize = 16 .
After changing that everything works fine.
Thank you all for your help.
philwilkinson40
Post by philwilkinson40 » Thu Oct 11, 2018 11:02 am
sorry to add to an old thread, but it seems relevant.
I am using a clone TinyDS1307 with a WEMOS D1 mini Pro ESP8266.
All works well but the RTC time does not survive a power reset.
setting ds.halt(False) has the same outcome. I have tried the same code with the uRTC driver too with the same result. Am I doing this all wrong?
import ds1307
import ntptime
from machine import I2C, Pin
i2c = I2C(scl=Pin(5), sda=Pin(4))
ds = ds1307.DS1307(i2c)
print('initial datetime on ds1307 is...', ds.datetime())
#set the time by ntptime
print('ntp time is set at')
ntptime.settime()
f=utime.localtime()
g=f[0],f[1],f[2],f[6],(f[3]+8),f[4],f[5]
#ds.halt(False)
ds.datetime(g)
print('new datetime on ds1307 is...', ds.datetime())
utime.sleep(5)
print('5secs later is...', ds.datetime())
initially
initial datetime on ds1307 is... (2000, 1, 1, 0, 0, 0, 0, 0)
ntp time is set at
(2018, 10, 11, 10, 58, 26, 3, 284)
new datetime on ds1307 is... (2018, 10, 11, 3, 18, 58, 26, 0)
5secs later is... (2018, 10, 11, 3, 18, 58, 31, 0)
then after a power reset exactly the same occurs.
Online
mcauser
Post by mcauser » Thu Oct 11, 2018 2:51 pm
What’s the voltage on your coin cell?
philwilkinson40
Post by philwilkinson40 » Fri Oct 12, 2018 2:42 am
it was 2.85V, so I put in a brand new CR1220 which read over 3V. Unfortunately this has the same result.
I repeated this on a second tiny RTC clone with the same outcome.
Phil
Online
mcauser
Post by mcauser » Fri Oct 12, 2018 5:44 am
Is it the same RTC module as in the photo above?
I’ll give it a try with my D1 mini pro tonight.
