BME280 driver that works with ESP32?
Blechi
Post by Blechi » Mon Apr 23, 2018 6:50 pm
i'm trying to interface an ESP32 board (TT GO, latest loboris port) with a bme280 sensor (I2C, temperature, humidity, barometric pressure).
I couldn't find a driver for ESP32 so i tried the next best thing, which was catdo2's driver for the esp8266
(https://github.com/catdog2/mpy_bme280_esp8266).
Unfortunately it refuses to work.
When using bme280.py like this:
[code]
import micropython
import bme280
i2c = machine.I2C(scl=machine.Pin(22), sda=machine.Pin(21))
print(i2c.scan())
micropython.mem_info()
bme = bme280.BME280(i2c=i2c, address=118)
print(bme.values)
[/code]
I get this:
[code]
[80, 104, 118]
stack: 784 out of 19456
GC: total: 80000, used: 19872, free: 60128
No. of 1-blocks: 50, 2-blocks: 11, max blk sz: 530, max free sz: 2593
File "<stdin>", line 7, in <module>
AttributeError: 'module' object has no attribute 'BME280'
[/code]
My understanding is, that ESP8266 and ESP32 are slightly different animals, so that the ESP8266 code might not work as expected on ESP32.
Because my Python knowledge is basic at best, i have no idea what to do next.
Could someone more knowledgeable than me try to nudge me in the right direction?
Thank you very much in advance
Blechi
loboris
Re: BME280 driver that works with ESP32?
Post by loboris » Fri Apr 27, 2018 7:58 am
BME280 driver, tested and working well, is included in the repository: bme280.py.
There is also an example of how to run it in thread.
You can also copy it to the modules directory and build it as frozen module.
Blechi
Post by Blechi » Fri Apr 27, 2018 12:38 pm
Thank you very much for your reply.
Copying the BME280.py into the modules directory and building it as a frozen module did the trick.
Now it works fine.
Thank you again.
