Hi, I'm sorry for my lack of python etc, I'm completely new to all of this, but I'm using a Wemos D1 Mini running v1.9-6, and I bought a ssd1306 module. I downloaded the ssd1306.py from https://github.com/micropython/micropyt ... ssd1306.py and tried this program:
program:
import ssd1306
i2c = I2C(-1, sda=Pin(5, machine.Pin.OUT), scl=Pin(4, machine.Pin.OUT))
scan = i2c.scan()
print('address: ' + str(scan))
display = ssd1306.SSD1306_I2C(128, 64, i2c)
display.fill(0)
output:
address: [60]
File "<string>", line 49, in <module>
TypeError: function missing 1 required positional arguments
Any help appreciated
FYI:
>>> os.uname()
(sysname='esp8266', nodename='esp8266', release='2.0.0(5a875ba)', version='v1.9-6-g821dc27e-dirty on 2017-07-21', machine='ESP module with ESP8266')
ssd1306 display issue on wemos d1 mini
Re: ssd1306 display issue on wemos d1 mini
I think the problem is that your firmware is out of date. Please update to the current version and try again.
Peter,
Thanks you are completely correct, a firmware update as you suggested fixed the issue!
