PMS5003 air quality sensor library
IHOXOHI
Re: PMS5003 air quality sensor library
Post by IHOXOHI » Fri Jul 03, 2020 6:55 am
Maybe I have to wait this afternoon? 8-)
kevinkk525
Post by kevinkk525 » Fri Jul 03, 2020 7:11 am
Well that looks good. Do you get any other output after the 40 seconds it waits at start?
Kevin Köck
IHOXOHI
Post by IHOXOHI » Fri Jul 03, 2020 7:27 am
Yes, a lot!
first one: "
Got no available bytes
No response to wakeup command
wakeUp
wakeUp got lock
Sending command: 228,1,False,16000
waiting 40.0s
2nd one: "
Setting to active mode while sleeping
waiting 40.0s
3 :"
wakeUp
wakeUp got lock
waiting 40.0s
4:
Setting to passive mode whithout sleeping with 20s interval
waiting 40.0s
5:
Resetting not responding device
No reset pin defined, can't reset
Shutting device down as it is not responding
6:
Activating EcoMode, interval will be adapted to 60s
And nothing more... for moment, until more than 60 sec...
Thanks a lot!
kevinkk525
Post by kevinkk525 » Fri Jul 03, 2020 7:30 am
Is your device connected correctly?
Can you read something if you manually call uart.read()?
If both answers are yes then mabye uart.flush() needs a different workaround:
if self._uart.any():
    self._uart.read(self._uart.any())
Kevin Köck
IHOXOHI
Post by IHOXOHI » Fri Jul 03, 2020 8:15 am
I have connected :
rx-pms to tx-pyboard(X1)
tx-pms to rx-pyboard(X2)
gnd to gnd
vcc to v+
The "uart.read()"'s command return None. I have placed it just after the "uart = machine.UART(1, baudrate=9600)"'s command
I have reversed rx and tx connection without success.
I will test to change the flush command...
Thanks.
IHOXOHI
Post by IHOXOHI » Fri Jul 03, 2020 8:35 am
OK,
Sorry,
A simple mistake of me. I haven't change the pin correctly in my file...
Now I have this error:
>>> import pms5003_test
None
wakeUp
wakeUp got lock
waiting 40.0s
readFrame False False
__read_frame
readFrame got: (2, 2, 3, 2, 2, 3, 687, 187, 20, 2, 0, 0, 38656, 722)
Got (2, 2, 3, 2, 2, 3, 687, 187, 20, 2, 0, 0, 38656, 722)
device woke up
setPassiveMode
setPassiveMode got lock
Sending command: 225,0,True,1000
__read_frame
Received command response frame: [66, 77, 0, 4, 225, 0, 1, 116]
readFrame got: True
Got True
setPassiveMode done
wakeUp done
_read got lock
Sending command: 226,0,False,10000
__read_frame
got no values
  File "pms5003_test.py", line 105, in <module>
  File "pms5003_test.py", line 102, in start
  File "/sd/lib/uasyncio/core.py", line 109, in run_forever
  File "/sd/lib/pms/pms5003.py", line 354, in _read
  File "/sd/lib/pms/pms5003.py", line 260, in _sendCommand
  File "/sd/lib/pms/pms5003.py", line 412, in _read_frame
  File "/sd/lib/pms/pms5003.py", line 451, in __read_frame
TypeError: object of type 'NoneType' has no len()
IHOXOHI
Post by IHOXOHI » Fri Jul 03, 2020 10:08 am
Yo,
Same result with :
"if self._uart.any():
self._uart.read(self._uart.any())"
for replacing the flush's command...
Finally, It works, the frame contains values wich looks rights... No?
I have just to keep them in variables like "pms2.5 = frame[1]"
No?
kevinkk525
Post by kevinkk525 » Fri Jul 03, 2020 1:15 pm
I tried figuring out why you see that error but from the code I have, it is impossible that this error occurs in that line.
Can you post the code in line 451 just to be sure we have the same file? (we probably do but I just don't see how it is possible that the variable "buffer" in that line is suddenly "None" instead of a list)
Also please share you pms5003_test file.
No?
The frame looks good now. If you want to print the values use this:
pm.registerCallback(pm.print)
To read the values from the pm object you use:
pms25=pm.pm25_standard
The different values can be found in the documentation (the README.md)
Kevin Köck
IHOXOHI
Post by IHOXOHI » Fri Jul 03, 2020 2:36 pm
Yop,
my 451 line : "if len(data) != preframe_len and len(data) > 0:"
That's great! I'm very happy that the pms5003 works!
Thank you very much.
My sister is an aerosol researcher, and she doesn't have a better precision!
It's amazing!
For example, a virus coud be bigger than 0.3 um. (the covid is not far (0.12)). Very, very interessant data comes from pms5003. The example with smoke cigarets is kind.
I will can use it and tease my sister!
Kevin, your are a chief!
All my respect.
kevinkk525
Post by kevinkk525 » Fri Jul 03, 2020 3:46 pm
Ah of course, my bad. I forgot that the line number changed because of the workarounds for uart.flush()
Still strange that uart.read() would return "None" although the program waits until enough data is available in uart.any()..
But I added a workaround for that, hopefully that will help.
Try this file and let me know if it works correctly: https://github.com/kevinkk525/pms5003_m ... pms5003.py
I'm glad it works for you now!
Kevin Köck
