Drivers for OLED displays and portable GUI
Post by pythoncoder » Mon Sep 24, 2018 8:21 am
This nanogui project is intended to provide a simple GUI and graph plotting module portable to any display whose driver is subclassed from framebuf and which meets some other very simple requirements. The GUI is aimed at the display of sensor data. It has no provision for user input which must be handled in the application. To save RAM it uses 8 bit colour. Widgets are drawn using graphics primitives and hence may be scaled to very small displays.
If user input is required the official LCD160CR display with touch overlay should be used, with a GUI available here or for large 4.3" SSD1963 displays this one.
Display drivers are provided for Adafruit 1.5, 1.27 and 0.96 inch colour OLED displays. There is also the official SSD1306 driver for monochrome OLED displays. These may be used:
  • Alone (inheriting the framebuf graphics primitives).
  • With the CWriter class to display text in arbitrary fonts and colours.
  • Or with nanogui which builds on the CWriter class.
Some sample images. Small OLED displays are hard to photograph well. In practice they are very good with clear colours and extreme contrast. The following are samples from the test scripts running on a Pyboard with a 1.27" Adafruit display.
The meter levels, LED text strings and colours change dynamically as the data changes.
Analog clock. The widget is actually capable of displaying vectors of varying length, as straight line pointers or as arrows.
The plot module displaying analog data being captured in (slow) real time.
The Nokia 5110 with this driver may also be used with the monochrome Writer class to display arbitrary fonts, but the resolution of these displays is probably inadequate for the GUI.
kevinkk525
Re: Drivers for OLED displays and portable GUI
Post by kevinkk525 » Mon Sep 24, 2018 9:04 am
Sounds amazing!
When I have time to play with my SSD1306 I'll give it a try.
Kevin Köck
Cheaper options
Post by pythoncoder » Mon Sep 24, 2018 9:14 am
I should add that Adafruit colour OLED displays are expensive. I usually pay their prices to support the work they do and because their quality, documentation and code is great. But cheap Chinese displays are available. They are inevitably something of an unknown quantity; the one I tried worked fine.
cmisztur
Post by cmisztur » Wed Sep 26, 2018 2:31 am
This looks great. Thank You!
Jonwalter
Post by Jonwalter » Wed Nov 28, 2018 10:53 pm
Hey, pythoncoder!
Could you show the example of the calendar in same way like a clock or better. I really need for my new project, we create all kinds of widgets, etc. Now I have the first task to make an cool widget called economic calendar by Tradays - https://www.tradays.com/en/widget .
Thanks in advance! :oops:
Post by pythoncoder » Thu Nov 29, 2018 5:45 am
Alas I'm too busy with other (MicroPython) things to write custom code for people. Hopefully you can use my code as a template for extending the widget set.
It's an open question whether it's feasible to display a full month on a 1.5 inch display.
deshipu
Post by deshipu » Wed Dec 19, 2018 8:57 am
In case anybody finds it useful, I wrote an article about handling the small OLED displays without a library: https://hackaday.io/page/5722
