right_motor_en = machine.Pin('X1', machine.Pin.OUT)
right_motor_a = machine.Pin('X2', machine.Pin.OUT)
right_motor_b = machine.Pin('X3', machine.Pin.OUT)
right_pwm_timer = pyb.Timer(2, freq=1000)
right_pwm_channel = right_pwm_timer.channel(1, pyb.Timer.PWM, pin=right_motor_en)
right_pwm_channel.pulse_width_percent(100)
The above code is working for the right motor, I have tried several pin, timer and channel combinations for the left motor. Can you guys suggest what pins to use for the left motor and timer / channel selection? I really don't know what I'm doing
Thank you,
John Banes
