xpt2046
Jerremy09
Re: xpt2046
Post by Jerremy09 » Thu Nov 21, 2019 12:38 pm
Hmmm, why GPIO14? I thought that :
IO14 - CS used by TFT display - used in ILI9341
IO12 - CS used by touch leyer of TFT display
#Setup
import xpt2046_syn2
spi = machine.SPI(1, baudrate=32000000, miso=machine.Pin(19), mosi=machine.Pin(23), sck=machine.Pin(18))
ts_cs = machine.Pin(12, machine.Pin.OUT)
tft_cs = machine.Pin(14, machine.Pin.OUT)
touch = xpt2046_syn2.XPT2046(spi = spi, confidence=5, margin=50, delay=10, calibration=None)
#Default Values xpt2046_syn.XPT2046(spi = spi, confidence=5, margin=50, delay=10, calibration=None)
citac = 0
ts_cs.value(0)
tft_cs.value(0)
while citac<50:
stisk = touch.get_touch(initial=False, wait=True, raw=False, timeout=300)
stisk2 = touch.raw_touch()
print(str(stisk2))
citac = citac + 1
ts_cs.value(1)
tft_cs.value(1)
still receiving rame values "(512, 128)" :-(
Jerremy09
Re: xpt2046
Post by Jerremy09 » Thu Nov 21, 2019 1:01 pm
HEllo Thank you,
does it mean that IO14 should be 0?
I tested it with IO14 (1/0) and same result :-(
Roberthh - did you test the module also with another board that pyboard?
Jan
Jerremy09
Re: xpt2046
Post by Jerremy09 » Thu Nov 21, 2019 1:02 pm
#Setup
import xpt2046_syn2
citac = 0
ts_cs.value(0)
tft_cs.value(0)
while citac<50:
print(str(stisk2))
citac = citac + 1
ts_cs.value(1)
tft_cs.value(1)
Second test:
#Setup
import xpt2046_syn2
citac = 0
ts_cs.value(0)
tft_cs.value(1)
while citac<50:
print(str(stisk2))
citac = citac + 1
ts_cs.value(1)
tft_cs.value(0)
Re: xpt2046
Post by Roberthh » Thu Nov 21, 2019 2:04 pm
tft_cs should be 1.
And yes, I tested that with another board too, dont't know whther it was ESP32 or ESP8266. But I can repeat that with an ESP32. You may also try the non-SPI version. 512/128 is a strange value pair.
Re: xpt2046
Post by Roberthh » Thu Nov 21, 2019 2:57 pm
I found a reason: Thw SPI baud rate is too high. For the XPT2046 it must not be more than 2000000 (2 MHz).
Jerremy09
Re: xpt2046
Post by Jerremy09 » Thu Nov 21, 2019 7:39 pm
Hello Roberthh,
many thanks now I receive different values for different touch in differen part of display :-).
Thank you
Jan
solano8
Re: xpt2046
Post by solano8 » Fri Jan 17, 2020 4:13 pm
I have already made my first ili9341/xpt2046 project in Arduino, but since I am more comfortable with (Micro-)python I would like to use that for my second project using Lolin TFT-2.4 and Lolin D32 Pro.
Thanks to @Roberthh for his baud info (and @Jerremy09 for asking...) it works now with basic display and touch functionality using ili934xnew.py and xpt2046_syn.py. I will probably also need a xpt.rotate() function. Could not find that in the xpt2046_syn.py. Do you know how to enable that, @Roberthh?
I also have some calibration issues, getting x- and y-values outside the expected 240 x 320 boundary, from (3,-9) to (462,275) using the same parameters for xpt.get_touch as @Jerremy09. Is this easy to solve?
Re: xpt2046
Post by Roberthh » Fri Jan 17, 2020 4:57 pm
Rotations is a simple linear transformation, which you can do in your code, like: x_new = a + b * x, where the a and b values have to be determines experimentally. Rotating by 90° or 270° would then only require to swap x and y. I cannot help you much with the calibration values, since that would require access to a simalar touch and LCD device. But the transformation mentioned above would also cover the calibration. You can use raw=Trrue in the call to get_touch to get the raw values. If you do the transformation yourself, you do not need the built-in method.
Divergentti
Re: xpt2046
Post by Divergentti » Fri Jan 15, 2021 8:22 am
This saved my day!
I found 1.2 MHz best value in my case. I guess S/NR of the cabling / connectors might have something do with this as well.
gurrae
Re: xpt2046
Post by gurrae » Thu Feb 18, 2021 8:48 am
Hi.
I am using a ESP32 with a LOLIN 2.4" TFT display with XPT2046 touch-screen.
Everything works fine in C++ (display & touch).
Now I am trying to get the XPT2046 to work with my ESP32 & microPython.
The displaypart works fine in micropython with the ili934.py module (fonts, images lines etc.)
Now I want to read coordinates from the XPT2046.
Can I use a modified version of the xpt2046_syn.py ??
I have read the thread but realize that I need some additional info to solve my problem...
My display-init part of the program is :
import ili934
from machine import SPI, Pin
from xglcd_font import XglcdFont
spi = SPI(1, baudrate=27000000, sck=Pin(14), mosi=Pin(13))
# display_TFT = Display(spi, dc=Pin(4), cs=Pin(16), rst=Pin(17), width=240, height=320, rotation=180)
# width, height & rotation is optional
display_TFT = Display(spi, dc=Pin(4), cs=Pin(16), rst=Pin(17))
print('Loading unispace')
unispace = XglcdFont('fonts/Unispace12x24.c', 12, 24)
display_TFT.draw_text(0, 0, 'Hello World', unispace, color565(255, 255, 255))
(As you already know, in the LOLIN 2.4" TFT display, the display & the XPT2046 share the same SPI-bus, with unique CS-pins for the display & the touch-screen)
My Touch_CS pin is 13 (can be moved if necessary)
Can anyone please guide me and add the minimum codelines I need to read coordinates from the display ??
ili9341.py
"""ILI9341 LCD/Touch module."""
from time import sleep
from math import cos, sin, pi, radians
from sys import implementation
import ustruct
def color565(r, g, b):
    """Return RGB565 color value.
    Args:
        r (int): Red value.
        g (int): Green value.
        b (int): Blue value.
    return (r & 0xf8) << 8 | (g & 0xfc) << 3 | b >> 3
class Display(object):
    """Serial interface for 16-bit color (5-6-5 RGB) IL9341 display.
    Note:  All coordinates are zero based.
    # Command constants from ILI9341 datasheet
    NOP = const(0x00)  # No-op
    SWRESET = const(0x01)  # Software reset
    RDDID = const(0x04)  # Read display ID info
    RDDST = const(0x09)  # Read display status
    SLPIN = const(0x10)  # Enter sleep mode
    SLPOUT = const(0x11)  # Exit sleep mode
    PTLON = const(0x12)  # Partial mode on
    NORON = const(0x13)  # Normal display mode on
    RDMODE = const(0x0A)  # Read display power mode
    RDMADCTL = const(0x0B)  # Read display MADCTL
    RDPIXFMT = const(0x0C)  # Read display pixel format
    RDIMGFMT = const(0x0D)  # Read display image format
    RDSELFDIAG = const(0x0F)  # Read display self-diagnostic
    INVOFF = const(0x20)  # Display inversion off
    INVON = const(0x21)  # Display inversion on
    GAMMASET = const(0x26)  # Gamma set
    DISPLAY_OFF = const(0x28)  # Display off
    DISPLAY_ON = const(0x29)  # Display on
    SET_COLUMN = const(0x2A)  # Column address set
    SET_PAGE = const(0x2B)  # Page address set
    WRITE_RAM = const(0x2C)  # Memory write
    READ_RAM = const(0x2E)  # Memory read
    PTLAR = const(0x30)  # Partial area
    VSCRDEF = const(0x33)  # Vertical scrolling definition
    MADCTL = const(0x36)  # Memory access control
    VSCRSADD = const(0x37)  # Vertical scrolling start address
    PIXFMT = const(0x3A)  # COLMOD: Pixel format set
    FRMCTR1 = const(0xB1)  # Frame rate control (In normal mode/full colors)
    FRMCTR2 = const(0xB2)  # Frame rate control (In idle mode/8 colors)
    FRMCTR3 = const(0xB3)  # Frame rate control (In partial mode/full colors)
    INVCTR = const(0xB4)  # Display inversion control
    DFUNCTR = const(0xB6)  # Display function control
    PWCTR1 = const(0xC0)  # Power control 1
    PWCTR2 = const(0xC1)  # Power control 2
    PWCTRA = const(0xCB)  # Power control A
    PWCTRB = const(0xCF)  # Power control B
    VMCTR1 = const(0xC5)  # VCOM control 1
    VMCTR2 = const(0xC7)  # VCOM control 2
    RDID1 = const(0xDA)  # Read ID 1
    RDID2 = const(0xDB)  # Read ID 2
    RDID3 = const(0xDC)  # Read ID 3
    RDID4 = const(0xDD)  # Read ID 4
    GMCTRP1 = const(0xE0)  # Positive gamma correction
    GMCTRN1 = const(0xE1)  # Negative gamma correction
    DTCA = const(0xE8)  # Driver timing control A
    DTCB = const(0xEA)  # Driver timing control B
    POSC = const(0xED)  # Power on sequence control
    ENABLE3G = const(0xF2)  # Enable 3 gamma control
    PUMPRC = const(0xF7)  # Pump ratio control
    ROTATE = {
        0: 0x88,
        90: 0xE8,
        180: 0x48,
        270: 0x28
    def __init__(self, spi, cs, dc, rst,
                 width=240, height=320, rotation=180):
        """Initialize OLED.
        Args:
            spi (Class Spi):  SPI interface for OLED
            cs (Class Pin):  Chip select pin
            dc (Class Pin):  Data/Command pin
            rst (Class Pin):  Reset pin
            width (Optional int): Screen width (default 240)
            height (Optional int): Screen height (default 320)
            rotation (Optional int): Rotation must be 0 default, 90. 180 or 270
        self.spi = spi
        self.cs = cs
        self.dc = dc
        self.rst = rst
        self.width = width
        self.height = height
        if rotation not in self.ROTATE.keys():
            raise RuntimeError('Rotation must be 0, 90, 180 or 270.')
            self.rotation = self.ROTATE[rotation]
        # Initialize GPIO pins and set implementation specific methods
        if implementation.name == 'circuitpython':
            self.cs.switch_to_output(value=True)
            self.dc.switch_to_output(value=False)
            self.rst.switch_to_output(value=True)
            self.reset = self.reset_cpy
            self.write_cmd = self.write_cmd_cpy
            self.write_data = self.write_data_cpy
            self.cs.init(self.cs.OUT, value=1)
            self.dc.init(self.dc.OUT, value=0)
            self.rst.init(self.rst.OUT, value=1)
            self.reset = self.reset_mpy
            self.write_cmd = self.write_cmd_mpy
            self.write_data = self.write_data_mpy
        self.reset()
        # Send initialization commands
        self.write_cmd(self.SWRESET)  # Software reset
        sleep(.1)
        self.write_cmd(self.PWCTRB, 0x00, 0xC1, 0x30)  # Pwr ctrl B
        self.write_cmd(self.POSC, 0x64, 0x03, 0x12, 0x81)  # Pwr on seq. ctrl
        self.write_cmd(self.DTCA, 0x85, 0x00, 0x78)  # Driver timing ctrl A
        self.write_cmd(self.PWCTRA, 0x39, 0x2C, 0x00, 0x34, 0x02)  # Pwr ctrl A
        self.write_cmd(self.PUMPRC, 0x20)  # Pump ratio control
        self.write_cmd(self.DTCB, 0x00, 0x00)  # Driver timing ctrl B
        self.write_cmd(self.PWCTR1, 0x23)  # Pwr ctrl 1
        self.write_cmd(self.PWCTR2, 0x10)  # Pwr ctrl 2
        self.write_cmd(self.VMCTR1, 0x3E, 0x28)  # VCOM ctrl 1
        self.write_cmd(self.VMCTR2, 0x86)  # VCOM ctrl 2
        self.write_cmd(self.MADCTL, self.rotation)  # Memory access ctrl
        self.write_cmd(self.VSCRSADD, 0x00)  # Vertical scrolling start address
        self.write_cmd(self.PIXFMT, 0x55)  # COLMOD: Pixel format
        self.write_cmd(self.FRMCTR1, 0x00, 0x18)  # Frame rate ctrl
        self.write_cmd(self.DFUNCTR, 0x08, 0x82, 0x27)
        self.write_cmd(self.ENABLE3G, 0x00)  # Enable 3 gamma ctrl
        self.write_cmd(self.GAMMASET, 0x01)  # Gamma curve selected
        self.write_cmd(self.GMCTRP1, 0x0F, 0x31, 0x2B, 0x0C, 0x0E, 0x08, 0x4E,
                       0xF1, 0x37, 0x07, 0x10, 0x03, 0x0E, 0x09, 0x00)
        self.write_cmd(self.GMCTRN1, 0x00, 0x0E, 0x14, 0x03, 0x11, 0x07, 0x31,
                       0xC1, 0x48, 0x08, 0x0F, 0x0C, 0x31, 0x36, 0x0F)
        self.write_cmd(self.SLPOUT)  # Exit sleep
        sleep(.1)
        self.write_cmd(self.DISPLAY_ON)  # Display on
        sleep(.1)
        self.clear()
    def block(self, x0, y0, x1, y1, data):
        """Write a block of data to display.
        Args:
            x0 (int):  Starting X position.
            y0 (int):  Starting Y position.
            x1 (int):  Ending X position.
            y1 (int):  Ending Y position.
            data (bytes): Data buffer to write.
        self.write_cmd(self.SET_COLUMN, *ustruct.pack(">HH", x0, x1))
        self.write_cmd(self.SET_PAGE, *ustruct.pack(">HH", y0, y1))
        self.write_cmd(self.WRITE_RAM)
        self.write_data(data)
    def cleanup(self):
        """Clean up resources."""
        self.clear()
        self.display_off()
        self.spi.deinit()
        print('display off')
    def clear(self, color=0):
        """Clear display.
        Args:
            color (Optional int): RGB565 color value (Default: 0 = Black).
        w = self.width
        h = self.height
        # Clear display in 1024 byte blocks
        if color:
            line = color.to_bytes(2, 'big') * (w * 8)
            line = bytearray(w * 16)
        for y in range(0, h, 8):
            self.block(0, y, w - 1, y + 7, line)
    def contrast(self, level):
        """Set display contrast to specified level.
        Args:
            level (int): Contrast level (0 - 15).
        Note:
            Can pass list to specifiy
        assert(0 <= level < 16)
        self.write_cmd(self.CONTRAST_MASTER, level)
    def display_off(self):
        """Turn display off."""
        self.write_cmd(self.DISPLAY_OFF)
    def display_on(self):
        """Turn display on."""
    def draw_circle(self, x0, y0, r, color):
        """Draw a circle.
        Args:
            x0 (int): X coordinate of center point.
            y0 (int): Y coordinate of center point.
            r (int): Radius.
            color (int): RGB565 color value.
        f = 1 - r
        dx = 1
        dy = -r - r
        x = 0
        y = r
        self.draw_pixel(x0, y0 + r, color)
        self.draw_pixel(x0, y0 - r, color)
        self.draw_pixel(x0 + r, y0, color)
        self.draw_pixel(x0 - r, y0, color)
        while x < y:
            if f >= 0:
                y -= 1
                dy += 2
                f += dy
            x += 1
            dx += 2
            f += dx
            self.draw_pixel(x0 + x, y0 + y, color)
            self.draw_pixel(x0 - x, y0 + y, color)
            self.draw_pixel(x0 + x, y0 - y, color)
            self.draw_pixel(x0 - x, y0 - y, color)
            self.draw_pixel(x0 + y, y0 + x, color)
            self.draw_pixel(x0 - y, y0 + x, color)
            self.draw_pixel(x0 + y, y0 - x, color)
            self.draw_pixel(x0 - y, y0 - x, color)
    def draw_ellipse(self, x0, y0, a, b, color):
        """Draw an ellipse.
        Args:
            x0, y0 (int): Coordinates of center point.
            a (int): Semi axis horizontal.
            b (int): Semi axis vertical.
        Note:
            The center point is the center of the x0,y0 pixel.
            Since pixels are not divisible, the axes are integer rounded
            up to complete on a full pixel.  Therefore the major and
            minor axes are increased by 1.
        a2 = a * a
        b2 = b * b
        twoa2 = a2 + a2
        twob2 = b2 + b2
        x = 0
        y = b
        px = 0
        py = twoa2 * y
        # Plot initial points
        # Region 1
        p = round(b2 - (a2 * b) + (0.25 * a2))
        while px < py:
            x += 1
            px += twob2
            if p < 0:
                p += b2 + px
                y -= 1
                py -= twoa2
                p += b2 + px - py
        # Region 2
        p = round(b2 * (x + 0.5) * (x + 0.5) +
                  a2 * (y - 1) * (y - 1) - a2 * b2)
        while y > 0:
            y -= 1
            py -= twoa2
            if p > 0:
                p += a2 - py
                x += 1
                px += twob2
                p += a2 - py + px
    def draw_hline(self, x, y, w, color):
        """Draw a horizontal line.
        Args:
            x (int): Starting X position.
            y (int): Starting Y position.
            w (int): Width of line.
        if self.is_off_grid(x, y, x + w - 1, y):
            return
        line = color.to_bytes(2, 'big') * w
        self.block(x, y, x + w - 1, y, line)
    def draw_image(self, path, x=0, y=0, w=320, h=240):
        """Draw image from flash.
        Args:
            path (string): Image file path.
            x (int): X coordinate of image left.  Default is 0.
            y (int): Y coordinate of image top.  Default is 0.
            w (int): Width of image.  Default is 320.
            h (int): Height of image.  Default is 240.
        x2 = x + w - 1
        y2 = y + h - 1
        if self.is_off_grid(x, y, x2, y2):
            return
        with open(path, "rb") as f:
            chunk_height = 1024 // w
            chunk_count, remainder = divmod(h, chunk_height)
            chunk_size = chunk_height * w * 2
            chunk_y = y
            if chunk_count:
                for c in range(0, chunk_count):
                    buf = f.read(chunk_size)
                    self.block(x, chunk_y,
                               x2, chunk_y + chunk_height - 1,
                               buf)
                    chunk_y += chunk_height
            if remainder:
                buf = f.read(remainder * w * 2)
                           x2, chunk_y + remainder - 1,
                           buf)
    def draw_letter(self, x, y, letter, font, color, background=0,
                    landscape=False):
        """Draw a letter.
        Args:
            letter (string): Letter to draw.
            font (XglcdFont object): Font.
            background (int): RGB565 background color (default: black).
            landscape (bool): Orientation (default: False = portrait)
        buf, w, h = font.get_letter(letter, color, background, landscape)
        # Check for errors (Font could be missing specified letter)
        if w == 0:
            return w, h
        if landscape:
            y -= w
            if self.is_off_grid(x, y, x + h - 1, y + w - 1):
                return 0, 0
            self.block(x, y,
                       x + h - 1, y + w - 1,
                       buf)
            if self.is_off_grid(x, y, x + w - 1, y + h - 1):
                return 0, 0
            self.block(x, y,
                       x + w - 1, y + h - 1,
                       buf)
        return w, h
    def draw_line(self, x1, y1, x2, y2, color):
        """Draw a line using Bresenham's algorithm.
        Args:
            x1, y1 (int): Starting coordinates of the line
            x2, y2 (int): Ending coordinates of the line
        # Check for horizontal line
        if y1 == y2:
            if x1 > x2:
                x1, x2 = x2, x1
            self.draw_hline(x1, y1, x2 - x1 + 1, color)
            return
        # Check for vertical line
        if x1 == x2:
            if y1 > y2:
                y1, y2 = y2, y1
            self.draw_vline(x1, y1, y2 - y1 + 1, color)
            return
        # Confirm coordinates in boundary
        if self.is_off_grid(min(x1, x2), min(y1, y2),
                            max(x1, x2), max(y1, y2)):
            return
        # Changes in x, y
        dx = x2 - x1
        dy = y2 - y1
        # Determine how steep the line is
        is_steep = abs(dy) > abs(dx)
        # Rotate line
        if is_steep:
            x1, y1 = y1, x1
            x2, y2 = y2, x2
        # Swap start and end points if necessary
        if x1 > x2:
            x1, x2 = x2, x1
            y1, y2 = y2, y1
        # Recalculate differentials
        dx = x2 - x1
        dy = y2 - y1
        # Calculate error
        error = dx >> 1
        ystep = 1 if y1 < y2 else -1
        y = y1
        for x in range(x1, x2 + 1):
            # Had to reverse HW ????
            if not is_steep:
                self.draw_pixel(x, y, color)
                self.draw_pixel(y, x, color)
            error -= abs(dy)
            if error < 0:
                y += ystep
                error += dx
    def draw_lines(self, coords, color):
        """Draw multiple lines.
        Args:
            coords ([[int, int],...]): Line coordinate X, Y pairs
        # Starting point
        x1, y1 = coords[0]
        # Iterate through coordinates
        for i in range(1, len(coords)):
            x2, y2 = coords[i]
            self.draw_line(x1, y1, x2, y2, color)
            x1, y1 = x2, y2
    def draw_pixel(self, x, y, color):
        """Draw a single pixel.
        Args:
            x (int): X position.
            y (int): Y position.
        if self.is_off_grid(x, y, x, y):
            return
        self.block(x, y, x, y, color.to_bytes(2, 'big'))
    def draw_polygon(self, sides, x0, y0, r, color, rotate=0):
        """Draw an n-sided regular polygon.
        Args:
            sides (int): Number of polygon sides.
            r (int): Radius.
            rotate (Optional float): Rotation in degrees relative to origin.
        Note:
            Since pixels are not divisible, the radius is integer rounded
            up to complete on a full pixel.  Therefore diameter = 2 x r + 1.
        coords = []
        theta = radians(rotate)
        n = sides + 1
        for s in range(n):
            t = 2.0 * pi * s / sides + theta
            coords.append([int(r * cos(t) + x0), int(r * sin(t) + y0)])
        # Cast to python float first to fix rounding errors
        self.draw_lines(coords, color=color)
    def draw_rectangle(self, x, y, w, h, color):
        """Draw a rectangle.
        Args:
            w (int): Width of rectangle.
            h (int): Height of rectangle.
        x2 = x + w - 1
        y2 = y + h - 1
        self.draw_hline(x, y, w, color)
        self.draw_hline(x, y2, w, color)
        self.draw_vline(x, y, h, color)
        self.draw_vline(x2, y, h, color)
    def draw_sprite(self, buf, x, y, w, h):
        """Draw a sprite (optimized for horizontal drawing).
        Args:
            buf (bytearray): Buffer to draw.
            w (int): Width of drawing.
            h (int): Height of drawing.
        x2 = x + w - 1
        y2 = y + h - 1
            return
        self.block(x, y, x2, y2, buf)
    def draw_text(self, x, y, text, font, color,  background=0,
                  landscape=False, spacing=1):
        """Draw text.
        Args:
            text (string): Text to draw.
            spacing (int): Pixels between letters (default: 1)
        for letter in text:
            # Get letter array and letter dimensions
            w, h = self.draw_letter(x, y, letter, font, color, background,
                                    landscape)
            # Stop on error
            if w == 0 or h == 0:
                print('Invalid width {0} or height {1}'.format(w, h))
                return
            if landscape:
                # Fill in spacing
                if spacing:
                    self.fill_hrect(x, y - w - spacing, h, spacing, background)
                # Position y for next letter
                y -= (w + spacing)
                # Fill in spacing
                if spacing:
                    self.fill_hrect(x + w, y, spacing, h, background)
                # Position x for next letter
                x += (w + spacing)
                # # Fill in spacing
                # if spacing:
                #     self.fill_vrect(x + w, y, spacing, h, background)
                # # Position x for next letter
                # x += w + spacing
    def draw_vline(self, x, y, h, color):
        """Draw a vertical line.
        Args:
            h (int): Height of line.
        if self.is_off_grid(x, y, x, y + h):
            return
        line = color.to_bytes(2, 'big') * h
        self.block(x, y, x, y + h - 1, line)
    def fill_circle(self, x0, y0, r, color):
        """Draw a filled circle.
        Args:
            r (int): Radius.
        f = 1 - r
        dx = 1
        dy = -r - r
        x = 0
        y = r
        self.draw_vline(x0, y0 - r, 2 * r + 1, color)
        while x < y:
            if f >= 0:
                y -= 1
                dy += 2
                f += dy
            x += 1
            dx += 2
            f += dx
            self.draw_vline(x0 + x, y0 - y, 2 * y + 1, color)
            self.draw_vline(x0 - x, y0 - y, 2 * y + 1, color)
            self.draw_vline(x0 - y, y0 - x, 2 * x + 1, color)
            self.draw_vline(x0 + y, y0 - x, 2 * x + 1, color)
    def fill_ellipse(self, x0, y0, a, b, color):
        """Draw a filled ellipse.
        Args:
        Note:
        a2 = a * a
        b2 = b * b
        twoa2 = a2 + a2
        twob2 = b2 + b2
        x = 0
        y = b
        px = 0
        py = twoa2 * y
        self.draw_line(x0, y0 - y, x0, y0 + y, color)
        # Region 1
        while px < py:
            x += 1
            px += twob2
            if p < 0:
                p += b2 + px
                y -= 1
                py -= twoa2
                p += b2 + px - py
            self.draw_line(x0 + x, y0 - y, x0 + x, y0 + y, color)
            self.draw_line(x0 - x, y0 - y, x0 - x, y0 + y, color)
        # Region 2
        while y > 0:
            y -= 1
            py -= twoa2
            if p > 0:
                p += a2 - py
                x += 1
                px += twob2
                p += a2 - py + px
    def fill_hrect(self, x, y, w, h, color):
        """Draw a filled rectangle (optimized for horizontal drawing).
        Args:
            return
        chunk_y = y
        if chunk_count:
            buf = color.to_bytes(2, 'big') * chunk_size
                           x + w - 1, chunk_y + chunk_height - 1,
                           buf)
        if remainder:
            buf = color.to_bytes(2, 'big') * remainder * w
                       x + w - 1, chunk_y + remainder - 1,
                       buf)
    def fill_rectangle(self, x, y, w, h, color):
        """Draw a filled rectangle.
        Args:
            return
        if w > h:
            self.fill_hrect(x, y, w, h, color)
            self.fill_vrect(x, y, w, h, color)
    def fill_polygon(self, sides, x0, y0, r, color, rotate=0):
        """Draw a filled n-sided regular polygon.
        Args:
            r (int): Radius.
        Note:
        # Determine side coordinates
        coords = []
        n = sides + 1
        for s in range(n):
        # Starting point
        x1, y1 = coords[0]
        # Minimum Maximum X dict
        xdict = {y1: [x1, x1]}
        for row in coords[1:]:
            x2, y2 = row
            xprev, yprev = x2, y2
            # Calculate perimeter
            # Check for horizontal side
            if y1 == y2:
                if x1 > x2:
                    x1, x2 = x2, x1
                if y1 in xdict:
                    xdict[y1] = [min(x1, xdict[y1][0]), max(x2, xdict[y1][1])]
                    xdict[y1] = [x1, x2]
                x1, y1 = xprev, yprev
                continue
            # Non horizontal side
            # Changes in x, y
            dx = x2 - x1
            dy = y2 - y1
            # Rotate line
            if is_steep:
                x1, y1 = y1, x1
                x2, y2 = y2, x2
            if x1 > x2:
                x1, x2 = x2, x1
                y1, y2 = y2, y1
            dx = x2 - x1
            dy = y2 - y1
            # Calculate error
            error = dx >> 1
            y = y1
            # Calcualte minimum and maximum x values
                if is_steep:
                    if x in xdict:
                        xdict[x] = [min(y, xdict[x][0]), max(y, xdict[x][1])]
                        xdict[x] = [y, y]
                    if y in xdict:
                        xdict[y] = [min(x, xdict[y][0]), max(x, xdict[y][1])]
                        xdict[y] = [x, x]
                error -= abs(dy)
                if error < 0:
                    y += ystep
                    error += dx
        # Fill polygon
        for y, x in xdict.items():
            self.draw_hline(x[0], y, x[1] - x[0] + 2, color)
    def fill_vrect(self, x, y, w, h, color):
        """Draw a filled rectangle (optimized for vertical drawing).
        Args:
            return
        chunk_width = 1024 // h
        chunk_count, remainder = divmod(w, chunk_width)
        chunk_size = chunk_width * h
        chunk_x = x
        if chunk_count:
                self.block(chunk_x, y,
                           chunk_x + chunk_width - 1, y + h - 1,
                           buf)
                chunk_x += chunk_width
        if remainder:
            buf = color.to_bytes(2, 'big') * remainder * h
                       chunk_x + remainder - 1, y + h - 1,
                       buf)
    def is_off_grid(self, xmin, ymin, xmax, ymax):
        """Check if coordinates extend past display boundaries.
        Args:
            xmin (int): Minimum horizontal pixel.
            ymin (int): Minimum vertical pixel.
            xmax (int): Maximum horizontal pixel.
            ymax (int): Maximum vertical pixel.
        Returns:
            boolean: False = Coordinates OK, True = Error.
        if xmin < 0:
            print('x-coordinate: {0} below minimum of 0.'.format(xmin))
            return True
        if ymin < 0:
            print('y-coordinate: {0} below minimum of 0.'.format(ymin))
            return True
        if xmax >= self.width:
            print('x-coordinate: {0} above maximum of {1}.'.format(
                xmax, self.width - 1))
            return True
        if ymax >= self.height:
            print('y-coordinate: {0} above maximum of {1}.'.format(
                ymax, self.height - 1))
            return True
        return False
    def load_sprite(self, path, w, h):
        """Load sprite image.
        Args:
        Notes:
            w x h cannot exceed 2048
        buf_size = w * h * 2
            return f.read(buf_size)
    def reset_cpy(self):
        """Perform reset: Low=initialization, High=normal operation.
        Notes: CircuitPython implemntation
        self.rst.value = False
        sleep(.05)
        self.rst.value = True
        sleep(.05)
    def reset_mpy(self):
        Notes: MicroPython implemntation
        self.rst(0)
        sleep(.05)
        self.rst(1)
        sleep(.05)
    def scroll(self, y):
        """Scroll display vertically.
        Args:
            y (int): Number of pixels to scroll display.
        self.write_cmd(self.VSCRSADD, y >> 8, y & 0xFF)
    def set_scroll(self, top, bottom):
        """Set the height of the top and bottom scroll margins.
        Args:
            top (int): Height of top scroll margin
            bottom (int): Height of bottom scroll margin
        if top + bottom <= self.height:
            middle = self.height - (top + bottom)
            print(top, middle, bottom)
            self.write_cmd(self.VSCRDEF,
                           top >> 8,
                           top & 0xFF,
                           middle >> 8,
                           middle & 0xFF,
                           bottom >> 8,
                           bottom & 0xFF)
    def write_cmd_mpy(self, command, *args):
        """Write command to OLED (MicroPython).
        Args:
            command (byte): ILI9341 command code.
            *args (optional bytes): Data to transmit.
        self.dc(0)
        self.cs(0)
        self.spi.write(bytearray([command]))
        self.cs(1)
        # Handle any passed data
        if len(args) > 0:
            self.write_data(bytearray(args))
    def write_cmd_cpy(self, command, *args):
        """Write command to OLED (CircuitPython).
        Args:
        self.dc.value = False
        self.cs.value = False
        # Confirm SPI locked before writing
        while not self.spi.try_lock():
            pass
        self.spi.unlock()
        self.cs.value = True
        if len(args) > 0:
    def write_data_mpy(self, data):
        """Write data to OLED (MicroPython).
        Args:
            data (bytes): Data to transmit.
        self.dc(1)
        self.cs(0)
        self.spi.write(data)
        self.cs(1)
    def write_data_cpy(self, data):
        """Write data to OLED (CircuitPython).
        Args:
        self.dc.value = True
            pass
        self.spi.unlock()
