Anyone working on a MAX7219 8x8 LED matrix display library?
mcauser
Re: Anyone working on a MAX7219 8x8 LED matrix display library?
Post by mcauser » Sun Oct 01, 2017 2:16 pm
The visualisation tool produce bytes in the wrong format.
eg. "1" == 0x7e1818181c181800 == b'\x7e\x18\x18\x18\x1c\x18\x18\x00'
You'd need to reverse that to be b'\x00\x18\x18\x1c\x18\x18\x18\x7e'
Then convert from lsb to msb b'\x00\x18\x18\x38\x18\x18\x18\x7e'
Then draw each in the byte array down a single 8x8 segment.
Worth noting, my quad 8x8 module draws characters upside down compared to my individual 8x8 module boards.
Post by deshipu » Sun Oct 01, 2017 6:01 pm
I noticed you are mixing tabs and spaces in your code. This is a recipe for hard to find bugs, I really recommend configuring your text editor to use spaces all the time for Python code.
Otherwise, great work!
benalb
Post by benalb » Sun Oct 01, 2017 6:01 pm
Is this library exclusive for pyboard?. I have tried wiht an esp8266 module (lolin nodemcu) with:
esp8266 max7219
3v VCC
GND GND
d7(Pin 13) MOSI DIN
d8(Pin 15) CS CS
d5(Pin 14) SCK CLK
And then:
import max7219
spi = SPI(1)
display = max7219.Matrix8x8(spi, Pin(15), 1)
display.text('1',0,0,1)
display.show()
But the display lights all the leds, and nothing more.
mcauser
Post by mcauser » Sun Oct 01, 2017 11:29 pm
@deshipu fixed the tabs -> spaces. Thanks for that.
@benalb added ESP8266 eg to the readme. Had to drop the SPI freq from 80MHz to 10MHz to make it work.
benalb
Post by benalb » Mon Oct 02, 2017 6:28 am
mcauser wrote:@benalb added ESP8266 eg to the readme. Had to drop the SPI freq from 80MHz to 10MHz to make it work.
:D It works now, Thank you, great work.
d4ß
Post by d4ß » Thu Feb 15, 2018 5:02 pm
mcauser wrote:
Sun Oct 01, 2017 1:50 pm
I added cascading to deshipu's driver, and added framebuf to give text and shape support:
Works on my single 8x8 matrix, quad 8x8 matrices and 2x quad 8x8 matrices.
https://github.com/mcauser/micropython-max7219
If you have a chain of 4x 8x8 matrices and you want to only update the 2nd matrix (closest to the DIN matrix), you need to send NOOPs to each of the other matrices. You write to the furthest away from DIN matrix first. For each row, the right most pixel is the least significant bit.
eg. Light the top row of the 2nd matrix and leave the others unchanged.
_NOOP = const(0)
cs.low()
spi.write(bytearray([_NOOP, _NOOP]))
spi.write(bytearray([1, 255]))
cs.high()
Thank you mcauser.
Works well, only the scroll function is not performing as expected (maybe my bad?).
But I wrote my own:
import max7219
import utime
class max7219_Scroll:
    def __init__(self,CS,modules):
        self.CS = CS
        self.modules = modules
        self.spi = SPI(1, baudrate=10000000, polarity=0, phase=0)
        self.display = max7219.Matrix8x8(self.spi, Pin(self.CS), self.modules)
    def Scroll(self,tex, hell, repeat):
        self.display.brightness(hell)
        for r in range (0,repeat,1):
            for e in range (self.modules*8,-8*(self.modules+len(tex)),-1):
                self.display.fill(0)
                self.display.text(tex,e,0,1)
                self.display.show()
                utime.sleep(0.01)
DotMx=max7219_Scroll(2,4)
DotMx.Scroll(str('Hello, uPy!!!'),5,2)
{I am unable to attach a *.gif or *.m4a file to demonstrate the effect.}
mattyt
Post by mattyt » Fri Feb 16, 2018 3:24 am
Actually, I have a (currently quite hacky!) async scroll working against @mcauser's code somewhere. If anyone is interested I can polish it up and submit is as a pull request?
It's really not very different to @d4ß's solution (as I recall, add an async, sprinkle an await.asyncio.sleep...) but is non-blocking.
mcauser
Post by mcauser » Fri Feb 16, 2018 3:42 am
@d4ß The scroll method points to the FrameBuffer.scroll method:
http://docs.micropython.org/en/latest/w ... fer.scroll
It just shifts the contents of the FrameBuffer, leaving artefacts from the original buffer behind.
ie. if you scroll 1px from left to right, the 2 right most columns will be identical.
Your solution is similar to the one I recently created for a guy who emailed me asking similar.
We called it .marquee() after the obsolete html <marquee> tag.
https://developer.mozilla.org/en-US/doc ... nt/marquee
Currently supports left -> right, right -> left, up -> down, down -> up.
I wanted to add diagonal scrolling before I made a PR.
I'll share it soon.
I'm also working on a version where you can rotate individual matrices and arrange them in any order.
eg. 3x quad displays stacked in the shape of an S, or mixing quad displays with individual ones from different manufacturers where the orientation is different.
@mattyt an asyncio version sounds nice. I haven't played much with asyncio yet.
If you've got it working, submit a PR and I'll merge it in.
I'm going to add an examples folder with a ton of useful real world examples soon too.
mattyt
Post by mattyt » Sun Feb 18, 2018 9:56 pm
@mcauser if you have a neat marquee method then could you share that and I'll asyncify it? Better than having competing scroll methods, especially since my hacky solution only scrolls in one direction. :)
RobH
Post by RobH » Wed Apr 11, 2018 7:03 pm
Mike,
The MAX7219 driver works fine for me when using 'graphics' like pixel(), hline(), rect(), etc. but refuses to display text. And with scroll() the display blanks completely. I've tried with a single 8x8 and a quad 8x8, both with software-SPI and with ESP32 and ESP8266 with the latest firmware without success and without a clue what I could be doing wrong ;-) See also my code below.
Any suggestion?
Regards, Rob.
# test quadruple 8x8 led matrix with max7219 controller on ESP8266
import max7219
from time import sleep
spi = SPI(-1, baudrate=1000000, polarity=0, phase=0, sck=Pin(2), mosi=Pin(0), miso=Pin(5))
d = max7219.Matrix8x8(spi, Pin(4), 4)
d.brightness(4)
d.text=("7219",0,0,1)
d.show()
