24LC512 I2C memory
Posted: Sat Dec 07, 2019 4:22 am
does somebody used an I2C memory like a 24LC256 or I2C512 ?
Each time I try to write at any adress, I always read the same value :
But I always have the same result :
If somebody have an idea I will be grateful
Jacques
# I2C Memory : 24LC512
# Wired : A0, A1, A2 and WP to Vss (GND)
# 4k7 pullup resistors to Vdd (3.3V) on SCL and SDA pins
# The I2C memory response '80' to a i2c.scan()
from time import sleep_ms
I2C_BUS = I2C(1, scl=Pin(22), sda=Pin(21), freq=400000)
# Address in the 24LC512 where I try to read/write some data
adress_stock = 0x10
print("Adress R/W : ", adress_stock)
# Is there something before I try to write ?
print("Read before : ", I2C_BUS.readfrom_mem(80, adress_stock, 4 ) )
sleep_ms(10)
# Try to write '0x1234' in the memory at 0x10 adress
val = b'1234'
print("try to write : ", val )
I2C_BUS.writeto_mem(80, adress_stock, val)
sleep_ms(10)
# Does the memory received and stocked the information ?
print("verify : ", I2C_BUS.readfrom_mem(80, adress_stock, 4) )
>>> %Run -c $EDITOR_CONTENT
Adress R/W : 16
Read before : b'\xff\xff\xff\xff'
try to write : b'1234'
verify : b'\x00\x00\x00\x00'
Jacques
